Received: from d12lmsrelay.emea.ibm.com (d12lmsrelay.emea.ibm.com
[9.165.215.20])
by smtp3.ny.us.ibm.com (8.8.7/8.8.7) with ESMTP id DAA33618
for <murphy-rebel@dcsol.com>; Thu, 15 Oct 1998 03:22:02 -0400
Received: from DE.IBM.COM (d12lms01.emea.ibm.com [9.165.215.18])
by d12lmsrelay.emea.ibm.com (8.8.7/8.8.7) with SMTP id HAA27376
for <murphy-rebel@dcsol.com>; Thu, 15 Oct 1998 07:41:52 GMT
Received: by DE.IBM.COM (Soft-Switch LMS 3.0) with snapi via D12AU001
id 5120010017787383; Thu, 15 Oct 1998 07:31:43 +0000
Subject: Re: Motion flap drive spec
Message-ID: <5120010017787383000002L132*@MHS>
Date: Thu, 15 Oct 1998 07:31:43 +0000
MIME-Version: 1.0
Content-Type: text/plain; charset=iso-8859-1
Content-Transfer-Encoding: quoted-printable
Content-Disposition: inline
=0AHi Curt,
I didn't know you already have installed this particular unit. Great. N=
ow I
somebody to bother...
I like this flap motor because its light and small, yet powerful enough=
I did some sketches, because I have note purchased the unit yet
and thought it's too tight to attach it to the original cable point.
Do you happen to have a drawing or a picture of your setup?
Also, my German FAA equivalent wants flap position indicators; mechanic=
ally,
lights, instrument, anything is o.k.
Any ideas for this challenge?
Thanks. Cheers,
Stefan Pappe, Heidelberg, Germany, #156R=
Received: from Rebflyer@aol.com
by imo12.mx.aol.com (IMOv16.10) id EYGa019214
for <murphy-rebel@dcsol.com>; Wed, 21 Oct 1998 20:28:17 +2000 (EDT)
Message-ID: <1544194d.362e7c21@aol.com>
Date: Wed, 21 Oct 1998 20:28:17 EDT
Mime-Version: 1.0
X-Mailer: AOL 4.0 for Windows 95 sub 214
Hi Stephan,
Sorry, I don't have any pictures of the installation, but Murphy
aircraft
does. Dave Walker took pic's at Oshkosh. Said he may even post them on the
Murphy site. I haven't seen them yet. Actually the installation was very
straight forward. We had left the mixer arm bracket larger than the manual
had
asked for in anticipation of an electric system, so I'm not sure if that
will
effect anything or not, but we just added two brackets to support the top of
the motor, and bolted the bottom to the mixer arm in the original cable
hole.
As far as the indicator goes, I took one of the plastic latch blocks and
square tube, slotted the top and bottom and also slotted the door frame on
pilots side. I installed a #4 machine screw through the block, long enough
protrude about 3/8 into the door opening. I then installed a spring on the
forward end and ran a small cable to the mixer arm from the rear. As the
mixer
arm moves up the spring keeps the cable tight and slides the block and the
pin. As the mixer arm moves down it obviously pulls on the cable and slides
the block and pin in the other direction. I then just bent a tab behind the
pin(screw) and marked the appropriate points. We chose to mark neutral, +4
and +9 degrees up and -10 and -20 down. Whew!!! I hope that is a little
clearer that mud! I'm glad I don't have to write the manuals!! There has
also
been talk of lights but we chose to go mech.
Good luck, and keep at it. As I always say, the airplane is
worth it!!
Curt N97MR
Mime-Version: 1.0
Hi Stephan,
aircraft
had
will
hole.
mixer
also
worth it!!
Curt N97MR
