Rebel 659 - ailerons adjustments
Posted: Sat Feb 18, 2012 12:21 am
----- Original Message ----- From: allsure (allsure@iprimus.com.au)
To: Murphy Technical Department (murtech@murphyair.com)
Sent: Friday, October 26, 2001 11:53 PM
Subject: Fw: Rebel 659 - ailerons adjustments
Sent: Wednesday, October 24, 2001 9:10 PM
Subject: Rebel 659 - ailerons adjustments
G'day
Re: 10.0 Wing assembly (manual date 26/06/98) Page 54/55 Figure 10.12.4.
I have encountered a problem with the adjustment of the ailerons and would appreciate some advice.
I followed the instructions as described, using 1/8" and 1/16" hinge spacers (W605), and despite using all the combinations of spacers,
I cannot sufficiently adjust the hinges so that the aileron will clear the trailing edge of the wing.
However if I put a 1/8" or 3/16" of spacers under the top of the hinge, and none under the bottom part of the hinge, I can get satisfactory clearance. This of course flexes the hinge.
I guess my question is, can I safely pack up the top of the hinge and without any spacers on the bottom.
I would appreciate any assistance.
Thanks and regards
Ian Donaldson
G'day
Thanks and regards
Ian Donaldson
