SR Fuel Tank
Posted: Sat Feb 18, 2012 12:21 am
I am currently building the SR wings incorporating the 3500 mod. There is a
problem in doing this with the fuel section. The directions for the 3500 mod
doesn't work so well if you are building the wings from scratch. The problem
is with the leading edge doubler because it overlaps into not only the top
fuel skin but also the top wing skin. Therefore, if you follow the directions
of not riveting the top wing skin to the top fuel tank skin until after the
pressure test of the fuel tank, this will not work to well.
I talked to Grant at MAM and he had to give some thought to this problem. He
suggested that I go ahead and rivet the top wing skin to the top fuel tank
skin as well as to the doulber for the leading edgae. Therefore, you would
then check for fuel leaks after the wing is more or less rivetted together (at
least in the fuel area and the leading edge doubler. He also recomended that
with the extended fuel tanks, that I put in access pannels in the 2 remaining
bays on the bottom of the fuel tank skin. Then if there are any leaks, you
will have easy access through the bottom of the fuel tank to get at them and
seal them up.
I would like to add that in building the wings and incorporating the 3500 mod
has been very challenging as well as time consuming. Any suggestions on the
fuel tank area in regards to the 3500 mod is appreciated.
Todd S. Edgar
#95
seal them up.
Todd S. Edgar
#95
