Not a batch problem Tim! The RV1613 & 19 rivets have always (last 8 years
anyhow!) needed a light tap with a plastic hammer on the end of the rivet
gun, if going into a #11 hole of any substantial (over .063") material
thickness. Like they say better too tight, than too loose! There is the odd
one that is a real -itch to get in though. Most stuff being riveted with the
larger rivets is thick enough that it's not deformed by the extra exertion
required to get them in. Another trick is to take a piece of wooden dowel
about 6 inches long x 3/8" diameter and drill a centre hole in it that will
fit over the mandrel (or a piece of aluminum round bar stock is even
better). Use it as a driver to lightly tap the rivets in place.
Note that when doing solid rivets they do use a #10 drill for 3/16 rivets.
MAM has you using a #11 to give a tighter fit with the pull rivets as they
don't need as much clearance, since they are not solid or perfectly round.
Tim_Saxton@CreoScitex.com>
To: <
murphy-rebel@dcsol.com>
Sent: Monday, October 15, 2001 4:00 PM
Subject: RE: RV-1613 Rivets
Scott,
I've had exactly this problem. I've been using a drill guage to select the
rivets. If I can push (using firm hand pressure) the rivet through the #11
hole in the drill guage then I accept the rivet. Seems to shear off the
oversized edges of the rivet. Rivet will now insert okay into #11 drilled
hole. I've found about 1/3 of rivets will fail this test. This is not good
for my drill guage but at least I'm able to keep going with the RV-1613
rivets I have on hand.
My plan is to ask MAM to replace these rivets since they are clearly out
spec.
BTW, I received these rivets in Feb. this year. Might be a batch problem.
Tim
SR 060
flynski@peoplepc.com]
Sent: Monday, October 15, 2001 12:25 PM
To:
Subject: RV-1613 Rivets
My RV-1613 rivets don't seem to fit a #11 hole unless I use undo force.
Anyone else had this problem? The heads measure out to .193 with some .194
along the ridges. I just went to a #10 drill (.193) instead of #11 (.191)
Scott
murphy-rebel mailing list.
To unsubscribe from this list, send an e-mail to:
list-server@dcsol.com
For assistance contact
mike.davis@dcsol.com
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
