Mike K's LS1
Peter Cowan/Lexi Cameron
Mike K's LS1
Post by Peter Cowan/Lexi Cameron » Fri Feb 17, 2012 9:17 pm
Mike, what reduction drive are you planning to use?
Where are you located?
If you haven't already checked it out you might want to see the LS1 powered
Seabee in Ontario.
Peter.
Mike K's LS1
Post by Mike Kimball » Fri Feb 17, 2012 9:17 pm
I really like the CAM500 (http://www.aero-engines.bc.ca/cam500.htm) from
Firewall Forward in British Columbia, the Blackhawk Lightning
(http://www.aviaent.com/PSRU.htm#inside), and the Marcotte
(http://www.sdsefi.com/air14.html) for geared redrives, but I fear they will
all be to heavy and too expensive, so I will probably end up with a belt
drive from Chip Jones or maybe Belted Air Power. The only problem with
using a belt is that there is no provision for a constant speed prop.
On a different subject, I found a neat company that makes plastic engines
that I can use to build up my engine mount.
(http://www.payr.com/price_list.htm). Might be easier than dealing with the
heavy, real engine.
I have corresponded with the SeaBee owner. He seems very pleased with his
LS-1. I think you can get an LS-1 conversion from him for other SeaBees if
you want. I plan to build up my engine myself.
SR#044
Sent: Saturday, October 13, 2001 3:26 PM
Subject: Re: Mike K's LS1
Seabee in Ontario.
Peter.
murphy-rebel mailing list.
Mike K's LS1
Post by Bob Patterson » Fri Feb 17, 2012 9:17 pm
Hi Mike !
Last time I checked, the Marcotte drive was only $3,600 CDN -
pretty hard to beat that with a belt ! They also have provision
for a constant speed oil output, and look like a really beefy unit.
You can call Guy Marcotte at 418-362-2569.
-------------------------------orig.--------------------------------------
heavy, real engine.
SR#044
Seabee in Ontario.
Peter.
Mike K's LS1
Wow! I thought I remember you telling me that the Marcotte was a good bet a
while ago, but I had no idea it was that inexpensive. Once again, weight
might make it impossible since the gear drives can weigh in as much as 90
pounds. I will definitely find out though. Thanks!
SR#044
Sent: Wednesday, October 17, 2001 12:21 PM
Subject: RE: Mike K's LS1
Hi Mike !
will
heavy, real engine.
SR#044
Seabee in Ontario.
Peter.
Mike K's LS1
Weight might not be tooooo critical for the SVX 6 cyl. Subaru -
it's a very compact engine, so the weight wouldn't be as far forward
as on a V-8.
You might want to talk to Jorge at Crossflow Engineering, as
they also have a compact re-drive that is part of their firewall-forward
Subaru package for the SR. They have one SR flying now, and another
very close .... www.crossflow.com
They're just up in Shelburne, Ont. - 519-925-5633.
Not cheap, but very nice units, complete, and well supported.
-------------------------------------orig.----------------------------------
SR#044
Hi Mike !
will
heavy, real engine.
SR#044
Seabee in Ontario.
Peter.
Mike's Email
Mike K's LS1
Post by Mike's Email » Fri Feb 17, 2012 9:17 pm
Yeah, I know all about CrossFlow and that is a tempting engine choice, but I really want a V8!
Reply To: murphy-rebel@dcsol.com
Sent: Thursday, October 18, 2001 12:18 PM
as on a V-8.
SR#044
Hi Mike !
will
heavy, real engine.
SR#044
Seabee in Ontario.
Peter.
klehman
Mike K's LS1
Post by klehman » Fri Feb 17, 2012 9:17 pm
The Marcotte was about the lightest drive I considered. Be careful to
note what is included, such as the flywheel, when comparing.
SR#044
Mike K's LS1
Hi Mike !
Bob or anyone, are there running engines with Marcotte's redrives out there?
After hearing about all the problems with the Ross units I'm not anxious to
be the test bed. Any contact info on users?
Thanks, Peter.
LisaFly99
Mike K's LS1
Post by LisaFly99 » Fri Feb 17, 2012 9:17 pm
In a message dated 10/21/01 10:13:46 PM Central Daylight Time, cowcam@pipcom.com writes:
PETE
What do you exactly mean? I'm running a Ross on a 2.2 Subaru. I've not had one problem. And was told by Ross if there ever was one it would be fixed or upgraded.
Just tell him the problem, send him the part and their would be a replacement on the way. Maybe you're talking about the bigger Cubic inch redrives? I wouldn't know about those, if their is a problem. I do know the Internet is a lot like building a plan e you can't do it on rummers or BS. Someone or there business could get hurt.
Phil&Lisa Smith
#460R
N414D
