SR vertical fin fairing...why not now?
Jason Beall
Post by Jason Beall » Fri Feb 17, 2012 9:17 pm
Hi all,
Just finished my SR vertical stabilizer. The manual
doesn't mention installing the fiberglass tip fairing
now? Why? I have mated the rudder to the fin to check
for fit...so it seems like a good time to install it!
Any other SR builders have any thoughts?
-Jason
Jason Beall
Super Rebel No. 131
Aberdeen, Scotland, UK
super_rebel131@yahoo.com
Do You Yahoo!?
Listen to your Yahoo! Mail messages from any phone.
http://phone.yahoo.com
Dave Qualley
Post by Dave Qualley » Fri Feb 17, 2012 9:17 pm
If you have the rudder installed, then I can't see any reason not to install
the tip now.. You'll want to have the rudder installed so that you can match
the top of the fairing with the top of the rudder..
#057SR
Jason Beall wrote:
Hi all,
-Jason
Jason Beall
Super Rebel No. 131
Do You Yahoo!?
murphy-rebel mailing list.
David Qualley
As Built Floor Plans Canada
3555 Pearkes Place
Port Coquitlam, BC, V3B 5E4
tel 604.944.3392
fax 604.831.7401
http://AsBuiltFloorPlans.COM
Post by Mike Kimball » Fri Feb 17, 2012 9:17 pm
Sure, mount it now if you want. Good idea to mate the rudder to the fin for
fitting the tip fairing. By the way, the manual never tells you to install
the fairings. There are no instructions for this. You're on your own. A
dremel tool with a cutting wheel works very nice. Take your time fitting,
cutting, refitting, etc. and it will turn out fine.
SR#044
Jason Beall
Sent: Friday, September 28, 2001 8:52 AM
Subject: SR vertical fin fairing...why not now?
Hi all,
-Jason
Jason Beall
Super Rebel No. 131
Do You Yahoo!?
