cabin riveting
Posted: Fri Feb 17, 2012 4:22 pm
by Mike Davis
Received: from ibm (1Cust191.tnt9.krk1.da.uu.net [208.255.226.191])
by smtp1.mailsrvcs.net with SMTP id BAA16085
for <murphy-rebel@dcsol.com>; Mon, 31 Aug 1998 01:02:27 -0500 (CDT)
Message-ID: <000901bdd4a4$49632000$03000004@ibm>
Subject: Re: cabin riveting
Date: Sun, 30 Aug 1998 22:57:48 -0700
MIME-Version: 1.0
Content-Type: text/plain;
charset="iso-8859-1"
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 4.72.3115.0
Hi Dan,
I would not use Proseal. It is primarily used for sealing fuel tanks because
of its high resistance to chemical attack. Save it just in case you need it
later if you develop leaks in your fuel system. There are much cheaper
solutions.
I would also stay away from silicone sealants. They do seal well, but you
cannot paint over them or the surfaces they have contacted, ever. There are
some good marine grade non-silicone caulking, such as BoatLife, that will do
a good job of sealing. I think their generic class is called polysulfides,
or something like that. I intend to seal all of the mating fuselage surfaces
and the rivets on at least the top and sides of the fuselage to keep
rainwater or melting snow out of the cabin.
Good Luck,
- Chuck -
To: murtech <murtech@murphyair.com>
Cc: murphy-rebel <murphy-rebel@dcsol.com>
Date: Sunday, August 30, 1998 10:05 PM
Subject: cabin riveting
Hello!
When can I rivet the cabin top (fus 28) to the bulkheads? And the
bottoms (fus 39 and 40)? I'm putting in spring gear.
I have no more proseal and plan to use silicone calking for an air
sealant around the cabin. Sounds good?
Dan Morehouse
R280
cabin riveting
by Mike Davis
Received: from chk1a10.dial.uniserve.ca [204.244.143.105]
by pop.uniserve.com with smtp (Exim 1.82 #4)
id 0zDZfE-0001u4-00; Mon, 31 Aug 1998 12:30:56 -0700
Message-Id: <2.2.16.19980831123024.2bdf177c@pop.uniserve.com>
X-Sender: murtech@pop.uniserve.com
X-Mailer: Windows Eudora Pro Version 2.2 (16)
Mime-Version: 1.0
From: Murphy Aircraft Tech Department <murtech@murphyair.com >
Date: Mon, 31 Aug 1998 12:30:56 -0700
At 10:57 PM 8/30/98 -0700, you wrote:
Hi Dan,
because
it
solutions.
are
do
surfaces
Good Luck,
- Chuck -
Hello!
Dan Morehouse
R280
Don't use silicone.>>
Murphy Aircraft Mfg. Ltd.
Ph: 1-604-792-5855
Fax: 1-604-792-7006
e-mail: murtech@murphyir.com
Web Site: http://www.murphyair.com
cabin riveting
by Mike Davis
Received: from [204.191.146.222] (helo=ts72-15.tor.istar.ca)
for murphy-rebel@dcsol.com
id 0zDby3-0001wP-00; Mon, 31 Aug 1998 17:58:32 -0400
Mime-Version: 1.0
Message-Id: <E0zDby3-0001wP-00@mail2.toronto.istar.net>
Date: Mon, 31 Aug 1998 17:58:32 -0400
Sounds terrible !! Most silicone gives off acid when it cures - keeps
eating into the aluminum for years !!
Silicone is almost impossible to paint over, as well.
What is the problem people are trying to solve ???!!!! Murphy
supplies epoxy zinc chromate with the kits because this is THE BEST SEALER,
BONDING AGENT, and CORROSION PROTECTION THERE IS !!!
Why the heck don't people use it ???!!!
We only have the epoxy chromate in our joints, and the rivets are
dipped in it. The aircraft have sat outside for over 8 years, and there are
no drips inside (other than the pilot) !!
If you use something rubbery in the joints, you will not get the
bonding strength of the epoxy, and, if it is too thick, you will even
weaken the joint and increase the shear load on the rivets.
There is a black rubbery adhesive that is now used to seal the
windshields. It come in a caulking gun type cartridge, and is paintable.
This is good stuff for windshields & skylights, and is readily available
through Murphy, or LP Plastics, the windshield guys.
....bobp
-----------------------------orig.--------------------------------------
At 09:43 PM 8/30/98 -0700, you wrote:
Hello!
Dan Morehouse
R280
cabin riveting
by Mike Davis
Received: from tim - 208.251.190.93 by email.msn.com with Microsoft SMTPSVC;
Mon, 31 Aug 1998 17:13:39 -0700
Reply-To: <tlcarter@msn.com>
To: "'Murphy Rebel'" <murphy-rebel@dcsol.com>
Subject: RE: cabin riveting
Date: Mon, 31 Aug 1998 15:33:55 -0700
Message-ID: <000701bdd53c$61d8e3c0$2a640a80@tim>
MIME-Version: 1.0
X-Priority: 3 (Normal)
X-Mailer: Microsoft Outlook 8.5, Build 4.71.2173.0
Importance: Normal
In-Reply-To: <E0zDby3-0001wP-00@mail2.toronto.istar.net>
Return-Path: tlcarter@email.msn.com
Bob:
I read your message to imply putting the cabin mating surfaces together
while the epoxy-chromate is still 'wet'....is that it?
You are referring to the Poly-Fiber epoxy-chromate?
Tim
#438R
Sent: Monday, August 31, 1998 2:59 PM
To: Murphy Rebel
....bobp
Hello!
Dan Morehouse
R280
cabin riveting
by Mike Davis
Received: from [204.191.147.75] (helo=ts67-12.tor.istar.ca)
id 0zE4Pc-0004v9-00; Wed, 2 Sep 1998 00:20:53 -0400
Mime-Version: 1.0
Message-Id: <E0zE4Pc-0004v9-00@mail2.toronto.istar.net>
Date: Wed, 2 Sep 1998 00:20:53 -0400
YES !!! The Poly-Fiber epoxy chromate is meant to bond surfaces
together WET. It doesn't do any good at all if both surfaces are coated
and allowed to dry before joining them.
(Sorry for the lecture, but this question keeps coming back !)
At 03:33 PM 8/31/98 -0700, you wrote:
Bob:
Tim
#438R
To: Murphy Rebel
....bobp
Hello!
Dan Morehouse
R280
