fus-5
Jones, Mike
fus-5
Post by Jones, Mike » Fri Feb 17, 2012 9:16 pm
hi murray
my rebel which was purchased partially built has fus5 cut in half and its a
pain in the but, dont do it, replace with whole tubes if you can
mike#007
Murray & Carol
fus-5
Post by Murray & Carol » Fri Feb 17, 2012 9:17 pm
Hi from Calgary:
Thanks to everyone who replied to my confusion on the FUS 5's. I very much
appreciate all your expertise and have decided to install the full uncut
tubes.
Thanks again
Murray Cherkas
REBEL 505
PK
FUS-5
Post by PK » Sat Feb 18, 2012 9:19 am
Question for Rebel builders - FUS-5:
In my kit I received two FUS-5 tubes. As Im not using spring gear I cut
one FUS-5 in half as per manual. The halves looked a bit slim so I read
the archives only to find out that cutting is not recommended, causes
grief when mounting floor ribs, controls, etc. So now I'm thinking of
using the full tube on the back of the cage, facing the cabin, and the
half tube on the front of the cage facing the firewall. The remaining
half tube will end up under the instrument panel.
Any opinions on this would be much appreciated.
Paul Kucera
Rebel 453R
FUS-5
Post by Wayne G. O'Shea » Sat Feb 18, 2012 9:19 am
Sounds like a GREAT plan Paul!
Sent: Wednesday, June 23, 2004 10:56 PM
Subject: FUS-5
Paul Kucera
Rebel 453R
