Prop balancer
LisaFly99
Prop balancer
Post by LisaFly99 » Sat Feb 18, 2012 12:16 am
In a message dated 9/4/01 9:00:04 PM Central Daylight Time,
Walter.Klatt@home.com writes:
, I do have a cheap simple prop balancer that I use that
can balance your prop, spinner and all hardware.
WALTER
Where did you get the prop balancer? Do you balance it on the engine, or on
the shop bench?
Phil&Lisa Smith #460R N414D
Prop balancer
Post by Walter Klatt » Sat Feb 18, 2012 12:16 am
It's called a Propmaster. Here is the site:
http://www.ulflight.com/
You balance the prop first, then the spinner and prop, and all your hardware. This is not on the airplane, so if your flywheel or crank is out, then you still need the expensive prop shop dynamic balancing. It works fine for small wooden or composite props, but not for the big metal ones. You can talk to the guy on email, and he can tell you what you need. Anyway, it worked fine for me.
From: murphy-rebel@dcsol.com [mailto:murphy-rebel@dcsol.com]On Behalf Of LisaFly99@aol.com
Sent: September 4, 2001 8:21 PM
Subject: Re: Prop balancer
WALTER
the shop bench?
