Tank Venting
Posted: Sat Feb 18, 2012 12:16 am
Ken and All.
Any aircraft I have worked on that is at, or has left, my facilities has
been fitted with a ram air vent to keep a positive pressure on the tanks and
any original holes that were drilled in the tank filler necks, by the
builder, were FILLED with a rivet. I DO NOT drill holes in the filler necks,
as that would negate the whole purpose of the ram air vent in the first
place. Either drill the large holes in the neck (and take your chances) or
use a ram air vent, NOT BOTH. You want the ram air vent to be like a pitot
tube that just holds pressure in the system. There is really no air flow
(other than what matches fuel flow) and this way if flying in the rain you
are not drawing in water either. If you have both vents you would be flowing
the rain in with the air flow that is coming in the ram vent and out the
fuel filler neck vents (oh ya only the air would come out the filler neck,
the water would drop in your tank!). This ram air + pressure is even more
critical in many aircraft I have viewed, due to the fact that the original
builder installed the fuel lines forward, up and around the front door post.
This means that in slow flight attitude (and even level flight for that
matter) when low on fuel all you need is a suction break, from fuel sloshing
away from the outlet, and the fuel will quit flowing. The positive pressure
in the tanks supplied by the ram air vent helps keep this from happening, or
enables the fuel to get flowing again if the suction is broken for an
instant. All I can offer for proof of concept is no fuel starvation
occurrences, hiccups etc. in over 6 years for Howard, myself (and all the
others I have shipped out of here) in any attitude, or fuel levels, with our
Rebels. We have screens installed in the vent tube to keep those pesky mud
wasps (or what ever damn bug does it) from filling the tube with dirt and
larva's.
Everyone's welcome to reinvent the wheel, but I'm sure going to think twice
about flying with you if you do!
Wayne G.O'Shea
Sent: Sunday, September 02, 2001 5:12 PM
Subject: Re: Sight guages
larva's.
Wayne G.O'Shea
vent airPerhaps this is a statement of the obvious but there must be much more
isflowing than fuel flow for this problem to occur which means that ram air
reduces theflowing into the J tube and out of the fuel cap vent. Anything that
tanksflow has to reduce the error. I put separate guage and vent ports in my
tends tobut I still don't like the idea of flowing air through the tank as it
tank.increase the likelihood of having a combustible fuel air ratio in the
sufficientKen
Bob Patterson wrote:Hi Brian !
Part of the problem might be because the vent tube is pointing
forward into the slipstream. Since it is meant to be just a vent, you
could try a straight vertical tube with a couple of saw cuts on the
back side, or bend the front of the tube down into an inverted "J",
so it doesn't get pressurized by ram air.
As Wayne suggests, you might want to check to see that you are
getting enough air INTO the tanks from the caps. I drilled 1/8" holes
at the front AND back of the filler neck, above the bottom of the
cap, so rain wouldn't get in, but lots of air could ! Lack of
volumeair through the caps is the reason for the cross tube & vent in the
first place .... (At least enough air must enter to replace the
blowof fuel used.)
.......bobpWayne, is there a way to redo the vent. Mine is cross vented and if I
get lowinto the hole the fuel gets blown out of the sight guages, so when I
BOTTOMit shows no fuel in the tanks. I have already put a restrictor in the
couldel of the sight guages and was wondering if there was something else I
*-------------------------------------------------------------------------*do to stop the pressure on the guage...Thanks....Brian
*-------------------------------------------------------------------------*You have received this message because you have subscribed to the
murphy-rebel mailing list.
