Received: from 486dx2-80 (unverified [205.182.69.229]) by merlin.netexp.net
(Rockliffe SMTPRA 2.1.4) with SMTP id <B0003047359@merlin.netexp.net> for
<Murphy-Rebel@dcsol.com>;
Fri, 21 Aug 1998 14:07:44 -0400
Message-ID: <B0003047359@merlin.netexp.net>
To: "Rebel Builders" <Murphy-Rebel@dcsol.com>
Subject: REBEL: fuel drain valves
Date: Fri, 21 Aug 1998 13:02:15 -0400
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 4.71.1712.3
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.2106.4
My manuel dosen't show them but I would like to put curtis style drain
valves in my wing tanks. I'd hate to put them in now and find out later
they interfere with the doors. Anyone else been there / done that?
Joel
Received: from [204.191.148.127] (helo=ts50-16.tor.istar.ca)
for murphy-rebel@dcsol.com
id 0zAJhy-0002EA-00; Sat, 22 Aug 1998 15:52:19 -0400
Mime-Version: 1.0
Subject: Re: REBEL: fuel drain valves
Message-Id: <E0zAJhy-0002EA-00@mail2.toronto.istar.net>
Date: Sat, 22 Aug 1998 15:52:19 -0400
The newer manuals DO show the fuel drains - they go at the back,
bottom of the tank. The valves come with the kit. They DO often hit the
window edging, the solution being to file/grind a small notch it the
edging strip.
If you can get the <almost> flush type drains that require a push
up pin type of fuel checker to use, they are a MUCH nicer solution. We have
them on number 1 - they look like a large (1/2") nut on the outside, with a
hole in the center. Because they only stick down about 1/8", they are no
problem to the doors or windows.
A drain on each of the tanks is VERY important !! You WILL get
condensation sooner or later, and this is the only easy way to get rid of
it.
Condensation in partially filled tanks is a VERY good reason to
consider carefully how large you are going to make the tanks in your REBEL !
Depending on the engine choice and mission profile, you may want smaller
tanks than the factory-supplied 3 bays/side (nominally 44 gal., but usually
actually 48 to 50 gal. !). For example, several people using the Rotax 912
that burns 3 gal/hr. have opted for 1 rib bay on the left side, and 2 bays
on the right, giving about 24 gal. - still 8 hours of flying !! Why carry
an extra 300 lb. of fuel, just to have full tanks ??!!
Smart float pilots heading into the boonies know that it is MUCH
better to take along several cans of gas in the baggage area, to leave
on the dock, for the flight home. This way, they can fly into small lakes
with minimal fuel, with good performance, and still have the fuel to get
home at the end of the weekend. They wouldn't get out of those small lakes
if they carried say 80 gal. ful fuel !!
Folks who have put in 80 gal. or larger tanks HAVE had problems with
fuel flow - 10 gallons would have been enough fuel, BUT it isn't very deep
when it's spread out over 10 rib bays !! The fuel outlets uncover in slips
Sorry, Joel - that sermon wasn't meant for you - it's just one of
my old standards !!
Off the soapbox and back to the airport for me !! Thanks for listening
------------------------------------orig.---------------------------
Mime-Version: 1.0
edging strip.
it.
my old standards !!
Joel
Received: from Rebflyer@aol.com
by imo18.mx.aol.com (IMOv14_b1.1) id EIJGa29489
for <murphy-rebel@dcsol.com>; Sun, 23 Aug 1998 21:23:13 +2000 (EDT)
Message-ID: <2418697b.35e0c082@aol.com>
Date: Sun, 23 Aug 1998 21:23:13 EDT
Mime-Version: 1.0
X-Mailer: AOL 4.0 for Windows 95 sub 214
HI JOEL, I AGREE WITH BOBP. ON THE FUEL DRAINS. THE GREATEST ADVANTAGE OF
THE CESSNA TYPE FLUSH STYLE IS NO NOTCHING THE DOOR. ALONG WITH THAT, IF
YOU
END UP SWINGING PART, OR ALL, OF YOUR DOOR THEY WILL STILL MISS. GOOD LUCK
AND KEEP AT IT , IT IS WORTH IT. CURT MARTIN N97MR
Mime-Version: 1.0
YOU
Received: from ocer.netexp.net (unverified [205.182.69.228]) by
merlin.netexp.net
(Rockliffe SMTPRA 2.1.4) with SMTP id <B0003077431@merlin.netexp.net> for
Mon, 24 Aug 1998 10:27:18 -0400
Message-ID: <B0003077431@merlin.netexp.net>
Date: Mon, 24 Aug 1998 10:45:51 -0400
X-Priority: 3
X-MimeOLE: Produced By Microsoft MimeOLE V4.71.1712.3
To: Murphy Rebel <murphy-rebel@dcsol.com>
Date: Saturday, August 22, 1998 3:45 PM
drains I bought are 1/4" NPT. Maybe if I have a problem I could just swap
them out.
Ya know, I would think so too, BUT my Luscombe has wing tanks and has no
drains on them??? Also it seems the gascolator could trap an awful lot of
water before any could get to the engine.
the other is ready to goop up and rivet together. I'll be using a Subaru
2.2L engine and expect to burn about 6 GPH.
Joel
merlin.netexp.net
X-Priority: 3
Don't think I like that solution.The newer manuals DO show the fuel drains - they go at the back,
edging strip.
Do you know what type of threads are on those type drains? The CurtisIf you can get the <almost> flush type drains that require a push
them out.
it.A drain on each of the tanks is VERY important !! You WILL get
!Condensation in partially filled tanks is a VERY good reason to
Good point Bob. It's a little late for me though - one wings finnished andDepending on the engine choice and mission profile, you may want smaller
No problem Bob. I always enjoy reading your very informative posts.Sorry, Joel - that sermon wasn't meant for you - it's just one of
my old standards !!
Joel
Received: from [204.191.146.167] (helo=ts75-08.tor.istar.ca)
id 0zBQJw-0006FV-00; Tue, 25 Aug 1998 17:08:04 -0400
Mime-Version: 1.0
Message-Id: <E0zBQJw-0006FV-00@mail2.toronto.istar.net>
Date: Tue, 25 Aug 1998 17:08:04 -0400
The notch is only about 1/4" deep, and is cut into the aluminum strip
that you rivet onto the outside of the square tube that forms the window
frame. It is hardly noticeable.
Sorry, I don't know the size or thread on the flush mount fittings,
but I'm sure someone out there can tell you ! Curtis or Bill ??
....bobp
-------------------------------orig.--------------------------------
Mime-Version: 1.0
....bobp
have-----Original Message-----
edging strip.If you can get the <almost> flush type drains that require a push
athem on number 1 - they look like a large (1/2") nut on the outside, with
usuallyDo you know what type of threads are on those type drains? The Curtishole in the center. Because they only stick down about 1/8", they are no
them out.
consider carefully how large you are going to make the tanks in your REBELDepending on the engine choice and mission profile, you may want smaller
Good point Bob. It's a little late for me though - one wings finnished andactually 48 to 50 gal. !). For example, several people using the Rotax 912
my old standards !!
Joel
Received: from 486dx2-80 (unverified [205.182.69.233]) by merlin.netexp.net
(Rockliffe SMTPRA 2.1.4) with SMTP id <B0003100550@merlin.netexp.net> for
Tue, 25 Aug 1998 19:46:16 -0400
Message-ID: <B0003100550@merlin.netexp.net>
Date: Tue, 25 Aug 1998 18:40:34 -0400
X-Priority: 3
Date: Tuesday, August 25, 1998 5:01 PM
think I'll go ahead and put them in. As far aft and inboard as possible,
right? Thanks.
Joel
X-Priority: 3
Oh, ok. For some reason I thought the square tube was being notched. IThe notch is only about 1/4" deep, and is cut into the aluminum strip
right? Thanks.
Joel
