throttle cables
Posted: Sat Feb 18, 2012 12:16 am
by Aurele Lavigne
Wayne O., Bob P. or anyone have the specs on the throttle cables and choke for the 912 Rebel, ei: part number, lenght, diameter etc., and any possible suppliers. I didn't see this any of my manuals.
Also, I'm having a hard time finding a local supplier (in Canada) that carries the NGK plug for the 912S or in myu case, 912 Extra piston kit, number DCPR8E.
Mine are due to be changed as housing are cracked in a few locations.
Thanks, Aurele
Rebel 063
throttle cables
Aurele, I don't know what you have for sure on yours, but they are usually just brake cables for a 10 speed bike!!!! There are different diameters of cable and cases available, so borrow someone's vernier or micrometer and measure the cable diameter. Then head to the CTC across the street and check out the bicycle section of the store.
My Father-in-law had trouble getting the DCPR8E plugs, even from the guy he bought the 912 XTRA pistons from. Have a feeling he is just running the original 912 plugs (7E's I believe).
Sent: Thursday, August 23, 2001 12:58 PM
Subject: throttle cables
Thanks, Aurele
Rebel 063
throttle cables
by Bob Patterson
Hi Aurele !
You should be able to order the throttle & choke cables from
Murphy. For the plugs, you might try NAPA Auto Parts, or any automotive
jobber - they will likely have to be a 'special order' of at least one
full box (10 plugs). That's what I did ....
--------------------------------------orig.----------------------------
number DCPR8E.
Thanks, Aurele
Rebel 063
<HTML><HEAD>
<META content="MSHTML 5.00.2614.3500" name=GENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=#ffffff>
<DIV><FONT face=Arial size=2>Wayne O., Bob P. or anyone have the specs on the
manuals.</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=Arial size=2>Also, I'm having a hard time finding a local
912
Extra piston kit, number DCPR8E.</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=Arial size=2>Mine are due to be changed as housing are cracked
in a few locations.</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=Arial size=2>Thanks, Aurele</FONT></DIV>
<DIV><FONT face=Arial size=2>Rebel 063</FONT></DIV></BODY></HTML>
throttle cables
by Aurele Lavigne
Wayne, thanks for the info on the cables, I did take a look at the bike stuff at CTC and will measure the diameter as you indicated to try and match. What should I measure, the cable itself or the housing, or both?
As for the plugs, I did manage to get them from Calafornia Precision ..., but it cost me dearly for shipping and then I found out Rotech in B.C. has them for about $5.92 each.
Aurele
Sent: Thursday, August 23, 2001 6:35 PM
Subject: Re: throttle cables
Thanks, Aurele
Rebel 063
throttle cables
Need to measure both as the case needs to match the cable if buying seperately. Seeing it's the case that is worn in your case, just measure the internal cable to match what you have and buy a complete assemble (cable/case) to match your current size.
Sent: Friday, August 24, 2001 7:17 PM
Aurele
Thanks, Aurele
Rebel 063
