Digest of list: murphy-rebel-d Total messages in digest: 2
1 Date : Mon, 30 Jul 2001 11:12:35 +0400
monty@emirates.net.ae
Subject: Epoxy Primer EP-420
2 Date : Mon, 30 Jul 2001 20:30:32 -0300
ricker@dbis.ns.ca
Subject: Wing Stringer Offset Question
---------- Digest Message #1 ----------
Date: Mon, 30 Jul 2001 11:12:35 +0400
To: murphy-rebel-d
I'm looking for a substitute for Poly-Fiber EP-420 that I can scrounge
from our engineering stores (Boeing or Airbus). Does anyone know the MIL
or BMS spec for EP-420. One potential product we have from the Airbus
product line is F-580-2010, Primer epoxy strontium chromate, used with a
hardener and a thinner. Will this do just as well? All suggestions
welcome.
Warren T. Montgomery
monty@emirates.net.ae>
Dubai, United Arab Emirates
---------- Digest Message #2 ----------
Date: Mon, 30 Jul 2001 20:30:32 -0300
ricker@dbis.ns.ca
To: murphy-rebel
This is a multi-part message in MIME format.
--------------9DB639962C3C8591FA75196C
Hi Folks
Quick question this evening, in the attached (scanned) sketch from the
wing assembly chapter, MAM says to offset the 4 indicated stringers by
".....3/4" in from the root end of the skin....", what is not so clear
(and not obvious given some past experience with the manual!) is whether
they want you to offset the stringers in from the root end toward the
inboard end of the skin or in to the wing toward the tip end. I am
guessing in toward the tip end but a second opinion would not hurt
here.... Is the overhang at the other end an issue?
Dave R.
Elite 583
David A. Ricker P. Eng.
Nova Scotia, Canada
Content-Type: application/pdf;
name="Stringer Position.pdf"
Content-Transfer-Encoding: base64
Content-Disposition: inline;
filename="Stringer Position.pdf"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--------------9DB639962C3C8591FA75196C--
