Epoxy Primer EP-420
Warren T. Montgomery
Epoxy Primer EP-420
Post by Warren T. Montgomery » Fri Feb 17, 2012 9:03 pm
I'm looking for a substitute for Poly-Fiber EP-420 that I can scrounge
from our engineering stores (Boeing or Airbus). Does anyone know the MIL
or BMS spec for EP-420. One potential product we have from the Airbus
product line is F-580-2010, Primer epoxy strontium chromate, used with a
hardener and a thinner. Will this do just as well? All suggestions
welcome.
<monty@emirates.net.ae>
Dubai, United Arab Emirates
bear
Epoxy Primer EP-420
Post by bear » Fri Feb 17, 2012 9:03 pm
Hi Warren, I missed you the last time you were in
Canada. I am using a Strontium primer that I get
from Endura in Edmonton. EP-PA SR 2 Part. Not
sure if this helps you considering where you are
located. What are you doing with the new doubler
on the wings for the 3500 upgrade. Are you
countersinking your rivets on the doubler. As you
know I have countersunk my leading edges and would
like to do the same on the doubler. Not sure I can
considering some rivets are 3/16 and 5/32. Any
suggestions?? I suppose I can flush the rest of
the leading edge and not do the doubler. Not sure
how that will look.
Gerry
Received: from omail2.emirates.net.ae
([194.170.168.4])
by dcsol.com (wcSMTP v5.4.449.4)
with SMTP id 189838812; Sun, 29 Jul 2001
23:20:47 -0800
Received: from pmail2.emirates.net.ae by
(Sun Internet Mail Server
sims.4.0.2000.10.12.16.25.p8)
with ESMTP id
<0GH900C6KYR9P3@omail2.emirates.net.ae> for
murphy-rebel-d@dcsol.com; Mon, 30 Jul 2001
11:13:57 +0400 (GST)
Received: from emirates.net.ae
([217.165.152.163]) by pmail2.emirates.net.ae
with ESMTP id
<0GH900A9LYR3SB@pmail2.emirates.net.ae> for
Date: Mon, 30 Jul 2001 11:12:35 +0400
From: "Warren T. Montgomery" <monty@emirates.net.ae>
Subject: Epoxy Primer EP-420
To: murphy-rebel-d@dcsol.com
Message-id: <3B6508E3.A6D8EDF5@emirates.net.ae>
Organization: PCC
MIME-version: 1.0
X-Mailer: Mozilla 4.76 [en] (Win95; U)
Content-type: text/plain; charset=us-ascii
X-Accept-Language: en
References: <6692656@dcsol.com>
welcome.
carol51
Epoxy Primer EP-420
Post by carol51 » Fri Feb 17, 2012 9:03 pm
Hi Warren:
I am also using Endura primer. This was recommended by our local supplier.
GOOD LUCK
REBEL 505
