Engine Price
Engine Price
Post by Mike Davis » Fri Feb 17, 2012 4:21 pm
Received: from home.com ([24.112.112.153]) by ha1.rdc1.bc.wave.home.com
(Post.Office MTA v3.5 release 217 ID# 1-1U40000L0S0V35)
with ESMTP id com for <murphy-rebel@dcsol.com>;
Thu, 6 Aug 1998 13:54:11 -0700
Message-ID: <35CA1778.F67A75F2@home.com>
Date: Thu, 06 Aug 1998 13:52:08 -0700
Reply-To: dqualley@home.com
Organization: Pacific Coast ent Ltd.
X-Mailer: Mozilla 4.02 [en]C-AtHome0402 (Win95; U)
MIME-Version: 1.0
To: Murphy Mailing List <murphy-rebel@dcsol.com>
Subject: Engine Price
I am building the Super Rebel and I have been offered a O-540 engine
for $10,000CAD/$6800US. It's from an Aztec that has been sitting for
some time. He is selling it at "Core price", and it comes with all
accesories.
Is this a good price for what I will be getting? How much more would I
be looking at for an overhaul or rebuild?
#057SR
Engine Price
Received: from Luscomb806@aol.com
by imo16.mx.aol.com (IMOv14_b1.1) id EXMZa27696
for <murphy-rebel@dcsol.com>; Thu, 6 Aug 1998 23:22:37 +2000 (EDT)
Message-ID: <b31494e4.35ca72ff@aol.com>
Date: Thu, 6 Aug 1998 23:22:37 EDT
Mime-Version: 1.0
Subject: Re: Engine Price
X-Mailer: AOL 3.0 for Windows 95 sub 62
Dave it sounds like a deal to me. I bought a IO470 Cont and will have
about
19000 after overhaul.
Les Vincent SR024
Engine Price
Received: from JCoughli@aol.com
by imo21.mx.aol.com (IMOv14_b1.1) id ENILa12330
for <murphy-rebel@dcsol.com>; Fri, 7 Aug 1998 03:00:43 -0400 (EDT)
Message-ID: <77a44201.35caa61d@aol.com>
Date: Fri, 7 Aug 1998 03:00:43 EDT
Mime-Version: 1.0
X-Mailer: AOL 3.0 16-bit for Windows sub 41
I have a lycoming 0235-n2c factory new engine to sell. Is anyone
interested??
Engine Price
Received: from MX180A@aol.com
by imo30.mx.aol.com (IMOv14_b1.1) id EJDWa12041
for <murphy-rebel@dcsol.com>; Fri, 7 Aug 1998 05:48:54 -0400 (EDT)
Message-ID: <b262c666.35cacd87@aol.com>
Date: Fri, 7 Aug 1998 05:48:54 EDT
Mime-Version: 1.0
X-Mailer: AOL 3.0 for Windows 95 sub 52
In a message dated 98-08-07 04:32:55 EDT, you write:
<< I have a lycoming 0235-n2c factory new engine to sell. Is anyone
interested?? >>
what is the price?
Bobby
Engine Price
Received: from chk1a17.dial.uniserve.ca [204.244.143.112]
by pop.uniserve.com with smtp (Exim 1.82 #4)
id 0z4teg-0005iR-00; Fri, 7 Aug 1998 14:02:31 -0700
Message-Id: <2.2.16.19980807140925.0ccf3d1e@pop.uniserve.com>
X-Sender: murtech@pop.uniserve.com
X-Mailer: Windows Eudora Pro Version 2.2 (16)
Mime-Version: 1.0
From: Murphy Aircraft Tech Department <murtech@murphyair.com >
Date: Fri, 7 Aug 1998 14:02:31 -0700
accesories.
#057SR
Hi Dave;
I am a total bone head when it comes to engine prices, perhaps some of the
other SR builders can help. One thing I know for sure is that you can really
get burnt buying an engine this way.
Regards;
Dennis>
Murphy Aircraft Mfg. Ltd.
Ph: 1-604-792-5855
Fax: 1-604-792-7006
e-mail: murtech@murphyir.com
Web Site: http://www.murphyair.com
Engine Price
Received: from tim - 208.251.189.167 by email.msn.com with Microsoft
SMTPSVC;
Fri, 7 Aug 1998 10:15:41 -0700
Reply-To: <tlcarter@msn.com>
To: "'Murphy Rebel'" <murphy-rebel@dcsol.com>
Subject: RE: Engine Price
Date: Fri, 7 Aug 1998 10:01:44 -0700
Message-ID: <000801bdc226$25c5aea0$2a640a80@tim>
MIME-Version: 1.0
charset="iso-8859-1"
X-Priority: 3 (Normal)
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook 8.5, Build 4.71.2173.0
Importance: Normal
In-Reply-To: <35CA1778.F67A75F2@home.com>
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.3110.3
Return-Path: tlcarter@email.msn.com
Dave:
Beware.
From the way you framed your question it looks like you may have not been
bitten by bad engine experiences before. The first things that spring to
mind are:
How long has it been sitting? Are there maintenance logs? How much total
time is on the engine? What is the current time to TBO now? What
accessories are included?
Basically, for an engine core to be good, it has to have a serviceable
crank, cam, rods and case. I will also help very much if the cylinder heads
are not cracked in the area of the spark-plug main boss, and if all the
cooling fins are intact other than that, cylinders can usually be overhauled
pretty well.
Anyway, I just realized in typing this that there is about a whole book's
worth of info on what might be involved in getting an engine such as this
back in the air. It is called:
The Major Overhaul
by Thomas
"Thomas. Subtitled: A Pilot's Guide. A book that demystifies the major
overhaul process. Find out exactly what constitutes a "new limits" major -
and how to save BIG money when the clock strikes TBO. An up-to-date,
technically accurate, unbiased introduction to the basics of the overhaul
process by one of the country's foremost authorities in engine matters.
Sftbd., 7"x 9 1/4", 312 pgs., 150 b&w ill."
121615.......$39.95
Available from Zenith Books: http://www.motorbooks.com/zenith.htm
If you are thinking that you can get this core and then build it up to suit
you, that is probably a good thought, although you'll need a good engine guy
to help you. I can suggest one that I use down here in California. He's
done two engines for me and frankly knows more than I ever will about this
process. (one is an O-320 for my Rebel)
To answer your real question, I don't see the price you quoted for the core
being that much of a bargain. You can check with Wentworth Aviation to
compare.
E-mail me directly at tlcarter@msn.com if you want to get in touch with a
good engine guy.
Be careful....it could be easy to spend more on a bargain than it is to buy
a complete overhaul and pay the core charge.
Go into this engine process informed as possible.
Tim
#438R
Sent: Thursday, August 06, 1998 1:52 PM
accesories.
#057SR
Engine Price
Received: from chk1a21.dial.uniserve.ca [204.244.143.116]
id 0z5wtp-00019d-00; Mon, 10 Aug 1998 11:42:30 -0700
Message-Id: <2.2.16.19980810114231.3f3707a0@pop.uniserve.com>
X-Sender: mursales@pop.uniserve.com
Mime-Version: 1.0
From: Murphy Sales Department <mursales@murphyair.com>
Date: Mon, 10 Aug 1998 11:42:30 -0700
Hi David,
My suggestion would be to give Bart a call at Progressive Air. It is rare
that we install a factory new engine in any of our demonstrators. All of our
engines over the past few years have either come from them or been
overhauled by them.
They are located in Kamloops, it might be worth your while to see if you can
take the engine to them to look over BEFORE making a commitment. Bart would
then be able to give you a better idea as to the overhaul costs as well.
Phone: 250-376-6226
Fax: 250-376-1995
Sunny Skies,
Colleen
Manufacturers of the Renegade, Renegade Spirit, Rebel,
Maverick, Rebel Elite & the 4/6 place Super Rebel
Web Site http://www.murphyair.com
See our SR and Elite on display at Oshosh Fly-In
in Oshkosh, WI July 29-August 4th
Engine Price
Received: from mime3.prodigy.com (mime3.prodigy.com [192.168.253.27])
by clmout1-int.prodigy.com (8.8.5/8.8.5) with ESMTP id VAA15800
for <murphy-rebel@dcsol.com>; Mon, 10 Aug 1998 21:01:25 -0400
Received: (from root@localhost) by mime3.prodigy.com (8.6.10/8.6.9) id
VAA14552 for murphy-rebel@dcsol.com; Mon, 10 Aug 1998 21:01:01 -0400
Message-Id: <199808110101.VAA14552@mime3.prodigy.com>
X-Mailer: Prodigy Internet GW(v0.9beta) - ae01dm04sc03
Date: Mon, 10 Aug 1998 21:01:01, -0500
How much are you asking? and where would one go to pick it up? Is it
complete?
Don Daly
Engine Price
Post by Mike Davis » Fri Feb 17, 2012 4:22 pm
by imo20.mx.aol.com (IMOv14_b1.1) id EYNSa19316
for <murphy-rebel@dcsol.com>; Sun, 16 Aug 1998 03:38:11 -0400 (EDT)
Message-ID: <36efeab1.35d68c64@aol.com>
Date: Sun, 16 Aug 1998 03:38:11 EDT
Mime-Version: 1.0
20,000
Engine Price
by imo26.mx.aol.com (IMOv16.3) id EQZSa28623
for <murphy-rebel@dcsol.com>; Sat, 29 Aug 1998 03:53:35 -0400 (EDT)
Message-ID: <77e0a056.35e7b37f@aol.com>>
Date: Sat, 29 Aug 1998 03:53:35 EDT
Mime-Version: 1.0
asking US 20,000
