Yes ! Blast tubes to cool the mags are highly recommended
by the overhaul shops. About a 1/2" hole will do, with almost any
kind of tubing to direct the cooling airflow onto the mag.
Even a bent-up sheet metal channel will help.
I just added them to my O-320, and, in a hurry, used the
plastic flex piping usually used to wrap bundles of wires, sealed
in with high temp. silicone - seems to work !
All things electronic seem to work better and longer when
kept cool, and mag coils and condensers can suffer from excess
heat.....
--------------------------orig.----------------------------------
At 10:57 PM 7/8/01 EDT, you wrote:
Hi Bob,
Do you guys cut holes in the baffling to duct cooling air to your mags?
Bruce G
murphy-rebel mailing list.
