tapered corner wrap
Posted: Fri Feb 17, 2012 4:21 pm
Received: from chk1a10.dial.uniserve.ca [204.244.143.105]
by pop.uniserve.com with smtp (Exim 1.82 #4)
id 0z0wTP-0005AZ-00; Mon, 27 Jul 1998 16:14:32 -0700
Message-Id: <2.2.16.19980727160702.37e735be@pop.uniserve.com>
X-Sender: murtech@pop.uniserve.com
X-Mailer: Windows Eudora Pro Version 2.2 (16)
Mime-Version: 1.0
From: Murphy Aircraft Tech Department <murtech@murphyair.com >
Subject: Re: tapered corner wrap
Date: Mon, 27 Jul 1998 16:14:32 -0700
At 06:41 PM 7/21/98 -0400, you wrote:
Ph: 1-604-792-5855
Fax: 1-604-792-7006
e-mail: murtech@murphyir.com
Web Site: http://www.murphyair.com
Mime-Version: 1.0
plywoodLikely a 'typo' - should read TRIAL. Just means hammer a bit, then
try the fit...
Since your Rebel kit has been around a while, and changed hands,
before you do very much work on the corner wraps, you should check the
THICKNESS of the ones you have. The later kits were upgraded to .025 thick
corner wraps, instead of the .020 used on earlier kits. (I believe
the NEW part number is FUS-70 ..) THe thicker corner wraps are HIGHLY
recommended, especially for heavier engines and/or rough ground.
While the old .020 corner wraps worked well enough, they were
VERY sensitive to dents - a small dent could grow to a crack quickly !
(voice of sad experience ;-( )
....bobp
---------------------------------orig.-----------------------------
At 08:58 AM 7/21/98 EDT, you wrote:Hello!
It is suggested to hammer the tapered corner wrap for the rebel into a
Murphy Aircraft Mfg. Ltd.fitting for a better fit. Then the manual says, 'While forming, make trail
fittings often.' What's that mean ? Fit it.
Also, I stumbled on a builder support page from Murphy's web site. Am I
missing anything here?
Dan
R280
Ph: 1-604-792-5855
Fax: 1-604-792-7006
