I would appreciate some opinions on the optional floor that goes from the
tailcone forward. I can see benefits in not having it: less work, less
weight, bottom skin exposed for inspection.
Besides being able to sleep on it, has anyone found any other pluses for
having it? Would just a partial floor, say from bulkhead C forward do?
Paul Kucera
Rebel 453R
Fus floor
Fus floor
Paul, one definite plus is added strength, but you also have the extra
weight and extra work(but it will only take a few extra hours.) Another
definite plus is mounting equipment back there in case you CG is too far
forward. But if you just want to go far enough back for baggage I think
that would be just fine. It's whatever you are looking for.
Good luck, Brian
Get your FREE download of MSN Explorer at http://explorer.msn.com
Good luck, Brian
_________________________________________________________________From: "C&P Kucera" <cpkucera@idirect.com>
Subject: Fus floor
Date: Sun, 17 Jun 2001 23:37:18 -0400
Paul Kucera
Rebel 453R
murphy-rebel mailing list.
Fus floor
Hi Paul !
Put the floor in. It will add considerably to the strength
of the fuselage cone (- and your resale value ;-)) It also makes
it easier to get back there to service the ELT, etc.
Don't forget the trick of using thin Mylar to drill your holes,
transferring them to the floor - and leaving one fuselage side clecoed
only, so you can reach in easily.
-------------------------------orig.---------------------------------------
Paul Kucera
Rebel 453R
