Received: from MMoreho699@aol.com
by imo20.mx.aol.com (IMOv14_b1.1) id EHGIa19316
for <murphy-rebel@dcsol.com>; Wed, 22 Jul 1998 10:52:49 -0400 (EDT)
Message-ID: <46877281.35b5fcc5@aol.com>
Date: Wed, 22 Jul 1998 10:52:49 EDT
Mime-Version: 1.0
Subject: rolled corner below side panel
X-Mailer: AOL for Macintosh sub 189
Hi!
When do I install the rolled corner below Fus 24 (side panel)? I've just
finished putting the tapered corner on the top. One of the next steps is to
put a tapered corner in front of the yet-to-be-installed bottom rolled
corner
in the cabin.
Dan
R280
Received: from chk1a10.dial.uniserve.ca [204.244.143.105]
by pop.uniserve.com with smtp (Exim 1.82 #4)
id 0z0wTR-0005AZ-00; Mon, 27 Jul 1998 16:14:33 -0700
Message-Id: <2.2.16.19980727160704.37e769f0@pop.uniserve.com>
X-Sender: murtech@pop.uniserve.com
X-Mailer: Windows Eudora Pro Version 2.2 (16)
Mime-Version: 1.0
From: Murphy Aircraft Tech Department <murtech@murphyair.com >
Subject: Re: rolled corner below side panel
Date: Mon, 27 Jul 1998 16:14:33 -0700
At 10:52 AM 7/22/98 EDT, you wrote:
Murphy Aircraft Mfg. Ltd.
Ph: 1-604-792-5855
Fax: 1-604-792-7006
e-mail: murtech@murphyir.com
Web Site: http://www.murphyair.com
Mime-Version: 1.0
cornerHi!
Now if you like.>in the cabin.
Dan
R280
Ph: 1-604-792-5855
Fax: 1-604-792-7006
