To Wayne...Re Reinforcing plates
Posted: Fri Feb 17, 2012 9:02 pm
G'day Wayne !
I've just completed your version of the firewall reinforcement......but I used .080" 6061-T6
(I got some plate cheap through a friend....and the 80 thou' was cheaper than 63 thou' !?!)
I've just had a rush of s#!t to the brain.......
I've only installed the two top plates.......not the bottom one as well.
Will the .080" spacing on the upper mounts affect the thrust line to the point where I should be fitting
something on the lower mounts to re-instate the correct angle for the engine....or do you think
this is a "non event" ?
(I haven;t put the cowls and nosebowl back on as yet....I'm also wondering how much the 80 thou'
is going to affect the clearance gap between the spinner and the nosebowl too)
Thanks for your advice ...it looks much better now...no buckling !
(The real pisser was the wiring looms and engine stuff through the firewall....nothing that three
full days work didn't fix !)....Couldn't go flying anyway....still waiting on the new oil cooler !
Rick & Wendy Harper
541R
Rick & Wendy Harper
541R
