tapered corner wrap; Murphy 'Account Support'
Post by Mike Davis » Fri Feb 17, 2012 7:21 pm
Received: from ibm (1Cust220.tnt6.sea1.da.uu.net [208.253.73.220])
by smtp2.mailsrvcs.net with SMTP id JAA10815
for <murphy-rebel@dcsol.com>; Tue, 21 Jul 1998 09:54:25 -0500 (CDT)
Message-ID: <000c01bdb4b7$1b395940$dc49fdd0@ibm>
Subject: Re: tapered corner wrap; Murphy 'Account Support'
Date: Tue, 21 Jul 1998 07:51:54 -0700
MIME-Version: 1.0
Content-Type: text/plain;
charset="iso-8859-1"
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 4.72.3110.5
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.3110.3
Hi Bob,
I think that's a typo. It should probably read "...make trial fittings
often." I think the idea is to hammer the corner wrap against a piece of
plywood, using it as sort of a trial mold until the piece fits. "Fitting"
here probably refers to how well the part fits (an eyeball judgement), as
opposed to a "fitting" that is a structural piece of metal. This would be
more precise and result in a neater look than just randomly bending or
hammering the corner wrap to fit. I suspect a good test is to place the
corner wrap in position and if it doesn't fit well or sticks out here and
there, gently smack it a few times to teach it who is boss. You want to do
that against a piece of plywood or something to prevent causing a local
dent. You should do your pounding on the bench and not on the plane so you
don't dent an unintended item.
I haven't worked on this part yet, so this is only my best guess. I also
suspect a stretcher/shirker would come in handy here, but I'm not sure it's
worth the bucks for the few times you need to use it.
Good Luck,
- Chuck -
To: murtech@murphyair.com <murtech@murphyair.com>; murphy-rebel@dcsol.com
Date: Tuesday, July 21, 1998 6:22 AM
Subject: tapered corner wrap; Murphy 'Account Support'
Hello!
It is suggested to hammer the tapered corner wrap for the rebel into a
plywood
fitting for a better fit. Then the manual says, 'While forming, make trail
fittings often.' What's that mean?
Also, I stumbled on a builder support page from Murphy's web site. Am I
missing anything here?
Dan
R280
