OK. I'm dense. I can't quite figure out the landing gear mod. It looks like it would be clear what to do if you were performing the mod on a completed airplane. Doing the mod at the right point in new construction is confusing me. If anyone can help, here are my questions:
Are FUS-87 and FUS-524 parts that are part of the original design or are they new, as part of the mod?
Can anyone give me an idea of what point in the construction this should be done?
Is there a good reason for including the access plate described in the mod, or is the access plate only needed for completed airplanes to get to the area in question?
Unrelated question: I've looked through all my parts and cannot find FUS-347, even though my inventory says I have it. These are the float attach brackets. Does anyone know what alloy, temper, and thickness of aluminum was used so I can make my own? If it's 6061-T6 I think that is what I can get at the local metal yard. I want to keep working and don't want to wait and pay for MAM to send me more.
SR Landing Gear Mod
bear
SR Landing Gear Mod
holes on 2 sides. Don't know the spec.FUS-347 is a 2"x2" tube 4 7/8" long with 11
Gerry
landing gear mod. It =
were performing the mod =looks like it would be clear what to do if you
right point in new =on a completed airplane. Doing the mod at the
help, here are my =construction is confusing me. If anyone can
the original design or are =questions:
construction this should =they new, as part of the mod?
plate described in the =be done?
completed airplanes to get =mod, or is the access plate only needed for
parts and cannot find =to the area in question?
it. These are the float =FUS-347, even though my inventory says I have
temper, and thickness of =attach brackets. Does anyone know what alloy,
6061-T6 I think that is =aluminum was used so I can make my own? If it's
to keep working and =what I can get at the local metal yard. I want
Rob Helt
SR Landing Gear Mod
Hi Mike;
Fus 87 and Fus 524 are part of the mod which has been available since last May. Apparently on the Murphy site they posted another service bulletin on the Under Carriage Drag Load Modification on March of 2001 but this is the same as the bulletin posted and received by SR builders in May of 2000. The pictures show that FUS 524 look like they are made of aluminum however in my mod kit they are made of stainless. It was easiest to install the mod at the stage where the torsion box is still open with the sill in place. Be careful that when you drill out FUS 87, make sure that Fus 524 is against the sill otherwise it will sit to high and the shear forces will be transferred along the rivets. This will then make the mod useless. If you are getting the 3500 upgrade kit I have received some pictures from Brian which show more work in this area as well so you may want to wait and do everything together. The access plate is only needed for completed floors.
Fus 347 are the float attach brackets which are included with your kit. If not received you should let Murphy know as they are very good at sending missing products quickly and with no charge. It doesn't mention in the manual but after these are fitted the should be riveted in place as doing it later is more difficult. Hope this helps
Rob Helt
SR023
Rob Helt
SR023
Sent: Tuesday, April 03, 2001 8:55 PM
Subject: SR Landing Gear Mod
bob.patterson
SR Landing Gear Mod
Received: from bretweir.total.net ([154.11.89.176])
by dcsol.com (wcSMTP v5.4.449.4)
with SMTP id 102686281; Tue, 03 Apr 2001 19:36:08 -0800
Received: (qmail 8485 invoked from network); 4 Apr 2001 03:35:55 -0000
Received: from unknown (HELO ip222.toronto84.dialup.canada.psi.net) (154.20.78.222)
by bretweir.total.net with SMTP; 4 Apr 2001 03:35:55 -0000
Mime-Version: 1.0
Subject: Re: SR Landing Gear Mod
Mike, and ALL !
FWIW, I would put in <every> access plate & hole you think you might
EVER need, while building. You never know when you might have to check
something on a trip, and it's MUCH easier if you already have a cover.
(been there, done that :-( )
------------------------------orig.-------------------------------------
area in question?
Mime-Version: 1.0
Mike, and ALL !
like it would be clear what to do if you were performing the mod on aOK. I'm dense. I can't quite figure out the landing gear mod. It looks
they new, as part of the mod?Are FUS-87 and FUS-524 parts that are part of the original design or are
done?Can anyone give me an idea of what point in the construction this should be
or is the access plate only needed for completed airplanes to get to theIs there a good reason for including the access plate described in the mod,
area in question?
FUS-347, even though my inventory says I have it. These are the floatUnrelated question: I've looked through all my parts and cannot find
figure outMike
<HTML><HEAD>
<META content="text/html; charset=iso-8859-1" http-equiv=Content-Type>
<META content="MSHTML 5.00.2614.3500" name=GENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=#ffffff>
<DIV><FONT face=Arial size=2>OK. I'm dense. I can't quite
herethe landing gear mod. It looks like it would be clear what to do if you
originalare my questions:</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=Arial>Are FUS-87 and FUS-524 parts that are part of the
airplanesdesign or are they new, as part of the mod?</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=Arial>Can anyone give me an idea of what point in the
construction this should be done?</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=Arial>Is there a good reason for including the access plate
partsto get to the area in question?</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=Arial>Unrelated question: I've looked through all my
working and don't want to wait and pay for MAM to send me more.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=Arial>Mike</FONT></DIV>
<DIV> </DIV>
<DIV> </DIV></BODY></HTML>
