Flywheel weight
Posted: Fri Feb 17, 2012 8:48 pm
Hi guys!
Just a word to let you know I've had my engine running with the new 13lb. weight added to the flywheel.
EEEEEEEEEEEEEEEEEEEEEEHHHHHHHHHHHHHHHHHHHHHHAAAAAAAAAAAAAAAAAAAAAAAA
What a difference. The engine runs alot smoother now.
Tomorrow will be the prop dial-in time.
Initially the 72" prop has been set at 14 degrees.
I was told by an engine specialist that I should re-set the carb set-up now because of the difference.
I think I remember you (Bobp :) ) saying that the aluminum props give you the best performance.
Now that I have doubled my mass on the crankshaft, I can see why. The extra weight allows the engine to run smoother thus not waisting energy shaking the plane.
I can also see this adding to the longevity of the engine life.
That's it for now.
Another report tomorrow after the flight.
Rick Ford
436R
That's it for now.
Rick Ford
436R
