bulkhead F
Posted: Fri Feb 17, 2012 11:48 pm
Hello everyone,
Does anyone know if the bulkhead F ( the rear door bulkhead ) needs a
doubler at the top where you must drill a 3/4" hole for the fuel line to
pass through on its way to the rear. This hole comes close to the "u"
shaped cutout in the bulkhead and visually appears to substantially
weaken the bulkhead. I have added the float fix doubler on the outside
of the fuse in this area and this seems to provide additional strenght
in this area. This hole also clips bulkhead "G" but only cuts in about
1/4". The doubler would fit inside of the bulkhead "F"(channel) from the
rear and would be approx 1 3/4" wide x about 5" long to be fit inside of
the bulkhead and bridge over the "u" cutout. I'll probably fit another
piece of channel inside of the bulkhead in this area.
Bulkheads "F" and "G" support the rear wing attach bracket and this is
the reason for my concern.
Thanks all in advance,
Rick D.
Rick D.
