cutting holes
carol51
cutting holes
Post by carol51 » Fri Feb 17, 2012 8:48 pm
Hi from Calgary;
How do you cut an inspection hole(a nice hole).
Scratched my head, got a scrap piece of aluminum, left hand tin snips, nope not a good idea. Went to the House of Tools bought left hand offset snips, don't go there. Took the snips back to House of Tools along with a piece aluminum, explaned my case and came up with a "nibler".Couldn't justify electric $$$$$, tried the poor mans give it a squeeze kind in the store, $20:00 bucks later, I'm a happy camper.
To get started you have to drill a 1/2" hole. Piece of cake.
I felt I had to write this just in case anyone else is scratching their head.
REBEL 505
Drew and Jan
cutting holes
Post by Drew and Jan » Fri Feb 17, 2012 8:48 pm
Hi 505 Another good way to cut holes is to use a circle cutter drill
attachment. It's best used with a drill press but I've used it by hand with
my cordless drill and slow speed. I made all my instrument cutouts with it
lightening holes in my spars and inspection holes in my floats with no
problems.
bob.patterson
cutting holes
Post by bob.patterson » Fri Feb 17, 2012 8:48 pm
Received: from bretweir.total.net ([154.11.89.176])
by dcsol.com (wcSMTP v5.4.449.4)
with SMTP id 283721984; Sat, 17 Mar 2001 19:12:29 -0900
Received: (qmail 25390 invoked from network); 18 Mar 2001 04:12:25 -0000
Received: from unknown (HELO ip186.toronto83.dialup.canada.psi.net) (154.20.77.186)
by bretweir.total.net with SMTP; 18 Mar 2001 04:12:25 -0000
Mime-Version: 1.0
Subject: Re: cutting holes
Hi !
There's an easier and safer way - just get a hole saw drill
attachment from Canadian Tire. They have sizes up to 3", and they
work nicely with a hand drill .....
Of course, that's a bit too small for instruments, but useable
for inspection holes. ;-)
If you need an inspection hole in the fuel tank, and have to
re-seal it, you are best to drill 2 overlapping round holes to leave
an OVAL hole. This way, you can easily insert the <oval> COVER, narrow
side first, and fasten it inside ...
-------------------------------orig.------------------------------------
At 10:29 PM 3/17/01 -0500, you wrote:
problems.
murphy-rebel mailing list.
Rick and Cathy Ford
cutting holes
Post by Rick and Cathy Ford » Fri Feb 17, 2012 8:48 pm
Rebel505
Yup! That's exactly how I did it.
Standing half crouched under the wing and 10 minutes per hole.
If you can do it before the wings goes on, it'll save the shoulder and neck muscles a vigorous workout.
REBEL436
Sent: Saturday, March 17, 2001 8:41 PM
Subject: cutting holes
Hi from Calgary;
REBEL 505
Legeorgen
cutting holes
Post by Legeorgen » Fri Feb 17, 2012 8:48 pm
Harbor freight sells a hole cutter with a fly wheel blade on both sides and
it's much easier to use without a drill press because it is balanced.
Bruce G
