Dorsal Fin on Rebel
Dorsal Fin on Rebel
Post by Mike Davis » Fri Feb 17, 2012 7:21 pm
Received: from interserv.com (van-as-10b13.direct.ca [204.174.245.77])
by m2.interserv.com (8.8.5/8.8.5) with ESMTP id UAA06613
for <murphy-rebel@dcsol.com>; Sun, 14 Jun 1998 20:52:52 -0700 (PDT)
Message-ID: <35849A5F.6CE64752@interserv.com>
Date: Sun, 14 Jun 1998 20:51:59 -0700
X-Mailer: Mozilla 4.05 [en] (Win95; U)
MIME-Version: 1.0
To: "(Murphy Rebel)" <murphy-rebel@dcsol.com>
Subject: Dorsal Fin on Rebel
Any thoughts on whether it is worth/necessary adding the
dorsal fin on the Rebel if flying on floats? What about on
wheels prior to going to floats?
Dorsal Fin on Rebel
Received: from chk1a16.dial.uniserve.ca (chk1a18.dial.uniserve.ca)
[204.244.143.111]
by pop.uniserve.com with smtp (Exim 1.82 #4)
id 0ylfFM-0003Kr-00; Mon, 15 Jun 1998 12:48:52 -0700
Message-Id: <2.2.16.19980615125230.09f7f504@pop.uniserve.com>
X-Sender: murtech@pop.uniserve.com
X-Mailer: Windows Eudora Pro Version 2.2 (16)
Mime-Version: 1.0
From: Murphy Aircraft Tech Department <murtech@murphyair.com >
Subject: Re: Dorsal Fin on Rebel
Date: Mon, 15 Jun 1998 12:48:52 -0700
In talking to Robin the Dorsal Fin does little to the flight
characteristics of the A/C one way or the other.
Regards;
Dennis
Murphy Aircraft Mfg. Ltd.
Ph: 1-604-792-5855
Fax: 1-604-792-7006
e-mail: murtech@murphyir.com
Web Site: http://www.murphyair.com
Dorsal Fin on Rebel
Received: from [204.191.150.29] (helo=ts28-14.tor.istar.ca)
for murphy-rebel@dcsol.com
id 0ym8xu-0001ih-00; Tue, 16 Jun 1998 23:32:50 -0400
Mime-Version: 1.0
Message-Id: <E0ym8xu-0001ih-00@mail2.toronto.istar.net>
Date: Tue, 16 Jun 1998 23:32:50 -0400
Walter,
Some people think the dorsal fin looks better - that's about it.
There
is no physical need for it...
It's like electric flaps, and control wheels .....
(Cessna did it, so it <must> be good !!) ;-)
....bobp
----------------------------------orig.------------------------------------
Dorsal Fin on Rebel
Received: from interserv.com (van-as-14b11.direct.ca [204.174.251.75])
by m2.interserv.com (8.8.5/8.8.5) with ESMTP id UAA16769
for <murphy-rebel@dcsol.com>; Tue, 16 Jun 1998 20:56:33 -0700 (PDT)
Message-ID: <35873E38.807D37EE@interserv.com>
Date: Tue, 16 Jun 1998 20:55:37 -0700
MIME-Version: 1.0
References: <E0ym8xu-0001ih-00@mail2.toronto.istar.net>
Hmmm, I think I like the looks of the Rebel better without the dorsal fin
really don't need the extra weight. The only reason I would have for doing
it,
would be to aid longitudinal stability with floats. Bit of a shame, though,
for
me, as I have already built and painted it, and was just about to do the
final
riveting. You guys are really sure that it doesn't help float flying?
Bob Patterson wrote:
Walter,
There
....bobp
Dorsal Fin on Rebel
Received: from [204.191.151.127] (helo=mail.inforamp.net)
id 0ymR70-00028k-00; Wed, 17 Jun 1998 18:55:26 -0400
Mime-Version: 1.0
Message-Id: <E0ymR70-00028k-00@mail2.toronto.istar.net>
Date: Wed, 17 Jun 1998 18:55:26 -0400
I've only had my Rebel on amphibs since Aug./96, but I sure haven't
noticed any problems with directional stability.
OTOH, if you've already got it done - go ahead and put it on ! It
shouldn't hurt (other than the weight, and a small increase in
weathercocking tendencies).
There are several Rebels on floats near here WITH the dorsal fin,
and several WITHOUT - no problems either way .....
....bobp
---------------------------------------orig.-------------------------------
it,
for
final
Walter,
There
....bobp
