Wing to Fuse Distance
Posted: Fri Feb 17, 2012 8:47 pm
Does anyone know the distance between the root rib and the fuselage? I'm
trying to figure out whether to use an angled bulkhead fitting for my pitot
tube installation, or to just use a straight one. I think straight would be
better to prevent a sharp turn inside the fuselage to wing fairing, assuming
I can come straight across from the wing to the fuselage with my nylon
tubing, then into the cabin. Is it OK to use 90 degree nylon fittings here
and there for the pitot tube?
