wiring and plumbing
Posted: Fri Feb 17, 2012 8:47 pm
Hi
I have been trying to read between the lines on Wayne and Bob's comments
on wiring.
Has anyone seen any problems in the lower corner wrap where all those
holes go through? Do any cracks develop at the holes? I don't even
recall seeing any doublers around these holes.
Brake lines, amphib gear lines, and perhaps pitot lines, wing wiring etc
can make a lot of holes in a somewhat delicate area. With difficulty,
some of the lines could go through the sidewall behind the cage but that
seems to be an area to be cautious of as well.
What is the best way to locate the holes? I was thinking that one large
hole with a doubler might be better than the swiss cheese approach. I
have also considered exiting the brake and hydraulic lines through the
0.040 floor pan forward of the rudder pedals and then back through a
covered exterior channel.
on wiring.
