[rebel-builders] wing root ribs
Post by Wayne G. O'Shea » Mon Feb 20, 2012 2:37 am
ALL wing rib flanges face the same way. There are no "left and right" wing
ribs. The solid "root" ribs are for both the root rib and the outboard fuel
tank rib... but you'd know that already having finished a wing.
Sent: Monday, January 30, 2012 4:04 PM
Subject: [rebel-builders] wing root ribs
Hello all,
I am just finishing the right wing and starting with the left.
Now I have 4 Wing root ribs 121-1 with the flanges to the same site.
Logically should there be 2 with RH flanges and 2 with LH flanges.
I can make the LH wing with flanges facing outward but is this ok
or do I have 2 incorrect wing root ribs?
Many thanks for any reply.
Marc van Hulzen
PH-REB
Roland Kriening
Post by Roland Kriening » Mon Feb 20, 2012 2:37 am
I believe on mine all the ribs were the same, with the flange on the same
(right) side. On the left wing flanges will face inward, on the right wing
they will face outward. The inboard of each wing will look different. I
believe there are additional angles you rivet on to the inboard of the right
wing. Stumped me when I got there, but I think the plans make mention of the
difference.
Wayne, Ron, and others will chime in if I am not explaining it correctly.
Roland
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Marc &
Janine
Sent: Monday, January 30, 2012 4:05 PM
Hello all,
Marc van Hulzen
PH-REB
Marc & Janine
Post by Marc & Janine » Mon Feb 20, 2012 2:37 am
Thanks you all for the replies.
Takes away the doubts.
Marc
-----Oorspronkelijk bericht-----
Van: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] Namens Roland
Kriening
Verzonden: maandag 30 januari 2012 22:28
Aan: rebel-builders@dcsol.com
Onderwerp: RE: [rebel-builders] wing root ribs
difference.
Roland
Janine
Hello all,
Marc van Hulzen
PH-REB
