Elite Spring Gear P/Ns, Was: Re: [rebel-builders] Fuselage C
David A. Ricker
Elite Spring Gear P/Ns, Was: Re: [rebel-builders] Fuselage Corner Wraps
Post by David A. Ricker » Sun Feb 19, 2012 11:36 pm
Bob
Are you building a taildragger or a tri-gear? Our tri-gear kit lists
SG-01AR & L as "spring gear, trike" right & left.
elite583.cjb.net
On 1/16/2012 7:25 PM, Wayne G. O'Shea wrote:
Many more than me that make this thing tick along Bob.. but thanks!
710E... so you're building an Elite.. it's supposed to come with FUS-452's
vs 70's for the lower front cage to firewall wraps. Not sure what their
intent is on the other pair, but I like a heavier set up on the back deck
between cabin and tail cone for hard tailwheel landings. The .020 Fus-10's
don't hold up there.
Do not know the difference between a 01A and 01. Hopefully it's just a
production modification... and not that one is for taildragger and the A's
are for tri-gear !
To:<rebel-builders@dcsol.com>
Sent: Monday, January 16, 2012 6:12 PM
Subject: [rebel-builders] Fuselage Corner Wraps
Hi All, I'm still drilling holes and filling them up with rivets on
Kit 710E
I started digging through my ' parts pile' looking for FUS-10 and FUS-70
and instead i find 4 of FUS-452. Are
these upgrades to go along with the float fittings that I have installed ?
Also I have Main Gear Legs SG-01A. I note in the book it calls for
SG-01 legs. Is there any big problem with
using the -01A legs on a tail drager or are they too short ?
Confused or What, Bob
PS enjoy reading the site, Thanks Wayne for being the ' go to' guy,
Bob
