Sent that too fast I meant toi add if you put the acess on top you can reach the nut and the bolt at the same time.
Sender: mike.davis@dcsol.com
Date: Wed, 11 Jan 2012 18:46:04
Subject: Re: [rebel-builders] LG 26 (centre tube) to Fuse 5s hardware access
I would put the holes on top just under the seat that way you will be able to reach
Date: Tue, 10 Jan 2012 13:06:14
Subject: [rebel-builders] LG 26 (centre tube) to Fuse 5s hardware access
Has anybody put access holes in the bottom skin (fuse 40) to get to the
5/16"nuts and washers on the LG 26 to Fuse 5s attachment?
I have the bungee gear and the Fuse 5s are not split. Any thoughts,
pros, cons, appreciated.
John Gleeson
Rebel 804 Down Under,
(where it's warm/hot) :-)
