[rebel-builders] Re: [rebel-builders] top tank skin removal
Posted: Mon Feb 20, 2012 2:36 am
Thanks for input, guys. So far, there's a consensus for going the bottom
route first. (I'm particularly impressed that Ken cut bottom holes in the
original tanks just to assure top sealing.) Counterpoints:
Obviously, it can be difficult to identify the true location of a leak from
the point where fuel appears outside. However, it's pretty clear that
perhaps some of the seepage appears around bottom rivets that are well
inside the tank perimeter. It's hard to fathom how those points, within
perimeter and up slope, could be attributable to poor sealing of the top
skin, even where it crosses interior ribs & stringers.
Another oddity is that although my tanks have been drained as much as
possible (even lifting the wings for final drops) and open for more than 45
days, I still have some persistent light weeping around some of the bottom
rivets in two locations, one near tank center! Hard to believe but true.
That would suggest there are areas where fuel is somehow trapped under the
bottom Pro-Seal such that it can't even evaporate. Also suggests more
reason to redo the whole shebang.
If the original top sealing is usually suspect, being the last item done,
from the top down, would sealing new bottom access holes be any more
reliable?
Is getting a new top skin from MAM a viable option? I'm guessing even if
MAM shipped one, eventually, there could be some anomalies trying to match
with existing holes, and the only real option for a new skin would be to
use the old as template for most of the holes, back marking the rest.
Assuming I cut bottom holes, how should I clean the existing Pro-Seal
inside to prepare it for overcoats? Slosh with [aviation] Simple Green,
well diluted in warm water? Scrub as best possible through the bottom holes
with some light degreasing solution? And/or...?
reliable?
