[rebel-builders] Warp drive or Prince prop
You won't be happy with the 4 blade Warp.. and it's just ugly to boot!
You'll get more help on the Prince prop if you tell everyone what the engine
and HP is...
The Clamars's are a great float and Clair will shoot me for saying it... but
IMHO heavy for a Rebel, so be aware and plan for it. With 180HP on an Elite
though (or if you have that in the Rebel)...they work great. They are a
GREAT performing float that makes up for some of the extra weight that they
are in comparison to the Murphy amphibs. (we are talking at least 160lbs
heavier). I did the very first Elite to Clamar amphib installation on the
planet and know it pretty intimately... then Clair came over and measured my
struts.. ;O)
To: "Rebel Builders" <rebel-builders@dcsol.com>
Sent: Friday, December 02, 2011 5:07 PM
Subject: [rebel-builders] Warp drive or Prince prop
I recently purchased a rebel which was on wheels (at the speed I do things
I would be 100 by the time it was finished). I also purchased a set of
Clamar floats that will be installed in the spring in time to be ready for
some fun at the cottage.
I need to purchase a new prop that will be pitched for the float
installation and was looking at the warp drive 4 blade version
(recommended by the manufacturer). I have been told by a couple of people
to go with the Prince prop instead.
Can anyone give me an insight on which would be better? If I went with
the prince, what would be the recommended diameter and pitch?
Regards
Wayne Barrett
Barrett Architect Inc.
708 Gerrard Street East
Toronto, Ontario, M4M 1Y3
Tel 416 469 8000
Fax 416 469 8056
Cel 416 587 1415
by rebflyer
Hi Wayne,
There has been alot of talk in the past over props, so the archives are a good place to peruse.
I started with a Warp drive 3 blade. I really liked the prop but I ended up cracking the aluminum at the blade end. I was sent a 4 blade replacement by Warp for the cost of 1 blade. Nice Customer service, but I did not like the way the 4 blades are held in the hub. I flew with it anyway as I was waiting for My 3 blade Catto prop. I didn't like the way the Warp 4 blade flew near as well as the 3 blade Warp.
I LOVE MY 3 BLADE CATTO!!!
When talking to Craig Catto the questions of engine HP and accessories (electronic ignition in particular) speeds of the aircraft and requested RPMs for takeoff customize the prop for your aircraft.
The TO rpm was right on. I like 2450 on the quick roll.
It weighs 13lbs! If you look at the takeoff contest in Alaska the winning aircraft is running a Catto.
I seem to remember someone running a 2 blade Catto on there Rebel but not sure who.
They will also put a erosion tape on the leading edge for you, but after many takeoffs and landings I have seen no sign of wear. I typically will do 5 to 10 operations in an 1.5 hr flight.
The only shortcoming I can see is you need to check the torque on the prop bolts a couple of times a season especially with large humidity and temp changes. It is a composite prop with a wood core.
I am not afiliated with Catto in any way other than being a happy customer.
Curt Martin
N97MR
650 hrs and still loving it!
To: Rebel Builders <rebel-builders@dcsol.com>
Sent: Fri, Dec 2, 2011 5:13 pm
I recently purchased a rebel which was on wheels (at the speed I do things I
ould be 100 by the time it was finished). I also purchased a set of Clamar
loats that will be installed in the spring in time to be ready for some fun at
he cottage.
I need to purchase a new prop that will be pitched for the float installation
nd was looking at the warp drive 4 blade version (recommended by the
anufacturer). I have been told by a couple of people to go with the Prince prop
nstead.
Can anyone give me an insight on which would be better? If I went with the
egards
Wayne Barrett
Tel 416 469 8000
ax 416 469 8056
el 416 587 1415
by Wayne
Sorry, the engine is a O-320, 150 hp.
Regards
Wayne Barrett
Tel 416 469 8000
Fax 416 469 8056
Cel 416 587 1415
and HP is...
struts.. ;O)
Regards
Wayne Barrett
Tel 416 469 8000
Fax 416 469 8056
Cel 416 587 1415
I'm running a 74-44 on mine (150HP) that came off a 160HP engine. It's just
a hair too coarse to get the full climb RPM that I would like.... but it's
working better than my Warp did and I'm getting out of SHORT back country
lakes with 2 big guys.. 25 gallons of fuel AND the canoe on the right side!
I'm thinking though.. that the prop I installed to Mark Morin's Rebel, 150HP
(Walter Klatt's old engine) was a 74-46 and he's happy with it. Lonnie
Prince's props seem to be here and there when it comes to specific engines
(and pitch they are supposed to be) and in the early days many went back for
a repitch before they got it right.
I'm with Curt as well... if I need to buy another prop, it will be a Catto !
(although I highly doubt I'll head for prop #5 !)
Wayne O'Shea
Cc: <rebel-builders@dcsol.com>
Sent: Friday, December 02, 2011 6:17 PM
Subject: Re: [rebel-builders] Warp drive or Prince prop
Regards
Wayne Barrett
Tel 416 469 8000
Fax 416 469 8056
Cel 416 587 1415
engine
and HP is...
but
Elite
they
my
struts.. ;O)
things
for
people
Regards
Wayne Barrett
Tel 416 469 8000
Fax 416 469 8056
Cel 416 587 1415
by Bob Patterson
Hi Wayne !
I totally agree with Wayne O .... The 4 blade Warp is a terrible
choice ! There's a ton of drag from it when you pull the power off,
so it revs up the engine on approach, with the throttle closed -
all engine guys agree this is really bad for aircraft engines !!
(High rpm - no fuel for cooling - pumping oil ... .... )
There's also the issue of blades cracking - for years, Warp would
not sell a prop for a Lyc - it cost them too much in replacements !
If you tell Prince your engine model & let him pick the pitch,
he will re-pitch free if he's wrong ! There are over 30 Rebels with
Prince props - almost all on amphibs. That said - the Catto looks
like a less expensive choice... Personally, go with 2 blades if
at all possible - always more efficient than 3 or 4 blades !
bobp@prosumers.ca
bobp@pattersys.com
http://www.Pattersys.com
responsibility of the reader.
Regards
Wayne Barrett
Tel 416 469 8000
Fax 416 469 8056
Cel 416 587 1415
Just to tidy up any "scares" Bobp has here.. Warp Drive BLADES have never
cracked or been thrown (to my knowledge)... it's only the aluminum
overmoulding that does so outside the hub clamp area. That said.. he should
have stuck with 70" diameter x 3 blade being his longest that he'd sel
instead of going to the 72"l. I ran my 70" from 1995 until removing it to
try the Prince in 2010... and only because I was too lazy to repitch the
Warp Drive to see if I could get better performance. I've had ZERO issues
with my Warp running it on both a 100HP x O-235-C and a 150 HP x O-320-C2A
Sent: Friday, December 02, 2011 7:28 PM
Hi Wayne !
bobp@prosumers.ca
bobp@pattersys.com
persons.
things
for
Regards
Wayne Barrett
Tel 416 469 8000
Fax 416 469 8056
Cel 416 587 1415
by Garry Wright
I checked with Sensenich in September about their ground adjustable (with
pin stop) prop, (composite) that they now have out for lower hp engines.
They say they are going to produce the O320 version of this suitable for
slow aircraft like the rebel during 2012. No further word on that yet. It
should have some advantages over other props in that you can pitch for
cruise to get there(easily), and re-pitch for climb to get off the water.
It is expensive though. Thinking about it.... One thing I don't know is
what the spinner looks like for such a prop. If it is as much work to
remove and replace as my existing spinner, I wouldn't be re-pitching
without a convenient location on land.
Garry
On Fri, Dec 2, 2011 at 5:42 PM, Wayne G. O'Shea <oifa@irishfield.on.ca>wrote:
Hi Wayne !
bobp@prosumers.ca
bobp@pattersys.com
persons.
things
for
people
Regards
Wayne Barrett
Tel 416 469 8000
Fax 416 469 8056
Cel 416 587 1415
by Walter Klatt
One of the guys here tried a 3 blade Cato on his Elite amphib when he
upgraded to the O-375 engine. On his first flight, he thought there must be
something wrong with his new engine, as his climb rate was less than his old
360 with the Sensenich. But after checking out the engine further and not
finding anything wrong, did some more flying with the new prop. On take-off
it only turned 2450, so he lost take-off performance, and poor top speed as
well, as it also quickly over revved in straight and level. After some phone
and email conversations with the Cato guy, he was not getting any
satisfaction.
Then I let him try my Sensenich from my 360, just to confirm if the new
engine was working properly. His take-off RPM went to 2550, so much better
take-off performance, his climb rate was way higher, and revved lower at
straight and level, but his top speed went up by about 20 mph. So the
Sensenich beat the Cato on take-off, climb and top speed performance.
He then bought a new Sensenich (same as mine that he tested with), and ended
up in a dispute with the Cato guy when he tried to return that prop. I think
the Cato might be better suited to Supercubs with a much lower speed range
than the Rebel.
One thing I learned about the Sensenich props back when I had the 150 hp
320, is that you can't over pitch them. They perform much better at finer
pitch, including top speed. Even 2 inches pitch makes a huge difference. I
found this out when flying with another identical Rebel amphib who had a 74
X 56, while I had a 74 X 54. I would beat him on take-off, climb and top
speed. He then re-pitched his to the same as mine, and our performance was
identical after that.
Another local Rebel amphib had a McCulley and he had really poor
performance. He then bought a Sensench, but the 56 pitch as he had the 160
hp. But he still couldn't match my performance even with the higher hp. He
then re-pitched his also to 54, and then had good performance. So even with
the high compression 320's the 54 pitch Sensenich is still better if you are
on amphibs.
BTW, I had a side by side fly-off with a 360 Supercub on straight floats
this summer from an alpine lake. Both of us had 2 people, and about 3/4
fuel. I got off the water first, much higher climb rate, and of course no
comparison in cruise with the much slower Supercub. So, needless to say, I
am still very happy with my Rebel amphib.
G. O'Shea
Sent: Friday, December 02, 2011 3:29 PM
Wayne O'Shea
Regards
Wayne Barrett
Tel 416 469 8000
Fax 416 469 8056
Cel 416 587 1415
engine
and HP is...
but
Elite
they
my
struts.. ;O)
things
for
people
Regards
Wayne Barrett
Tel 416 469 8000
Fax 416 469 8056
Cel 416 587 1415
by Wayne
Walter. Thank you very much for the information. This has been very informative. I currently have a sensenich So I will check the pitch and maybe reputch to what you have or go with a new 74 x 54. I am more interested in off the water and climb performance than cruise.
Regards
Wayne Barrett
Tel 416 469 8000
Fax 416 469 8056
Cel 416 587 1415
satisfaction.
than the Rebel.
on amphibs.
G. O'Shea
Wayne O'Shea
Regards
Wayne Barrett
Tel 416 469 8000
Fax 416 469 8056
Cel 416 587 1415
engine
and HP is...
but
Elite
they
my
struts.. ;O)
by Walter Klatt
You're most welcome, Wayne. Here on the west coast, we like to fly into
alpine lakes, and that's why so much attention to props and engines. When
you are on a small 3300 ft lake, loaded, on a warm day and glassy water,
that's when you really notice the smallest difference in props and engines.
Here's a video from about 5 years ago, flying into one of the local alpine
lakes here. The other plane was an identical Rebel amphib (and both of us
had 2 people on board), but he had the 160 hp 320, vs my lower compression
150. You will see that he didn't even get off the water the first time. And
near sea level, he used to think his performance was pretty good. It was
after this that he decided to change props.
http://www.youtube.com/watch?v=E2xgYyXJtM0
Sent: Sunday, December 04, 2011 7:27 AM
Regards
Wayne Barrett
Tel 416 469 8000
Fax 416 469 8056
Cel 416 587 1415
must be something wrong with his new engine, as his climb rate was
less than his old
not finding anything wrong, did some more flying with the new prop. On
take-off it only turned 2450, so he lost take-off performance, and
poor top speed as well, as it also quickly over revved in straight and
level. After some phone and email conversations with the Cato guy, he
was not getting any satisfaction.
new engine was working properly. His take-off RPM went to 2550, so
much better take-off performance, his climb rate was way higher, and
revved lower at straight and level, but his top speed went up by about
20 mph. So the Sensenich beat the Cato on take-off, climb and top speed
performance.
ended up in a dispute with the Cato guy when he tried to return that
prop. I think the Cato might be better suited to Supercubs with a much
lower speed range than the Rebel.
hp 320, is that you can't over pitch them. They perform much better at
finer pitch, including top speed. Even 2 inches pitch makes a huge
difference. I found this out when flying with another identical Rebel
amphib who had a 74 X 56, while I had a 74 X 54. I would beat him on
take-off, climb and top speed. He then re-pitched his to the same as
mine, and our performance was identical after that.
160 hp. But he still couldn't match my performance even with the
higher hp. He then re-pitched his also to 54, and then had good
performance. So even with the high compression 320's the 54 pitch
Sensenich is still better if you are on amphibs.
floats this summer from an alpine lake. Both of us had 2 people, and
about 3/4 fuel. I got off the water first, much higher climb rate, and
of course no comparison in cruise with the much slower Supercub. So,
needless to say, I am still very happy with my Rebel amphib.
just a hair too coarse to get the full climb RPM that I would like....
but it's working better than my Warp did and I'm getting out of SHORT
back country lakes with 2 big guys.. 25 gallons of fuel AND the canoe on
the right side!
150HP (Walter Klatt's old engine) was a 74-46 and he's happy with it.
Lonnie Prince's props seem to be here and there when it comes to
specific engines (and pitch they are supposed to be) and in the early
days many went back for a repitch before they got it right.
Wayne O'Shea
Regards
Wayne Barrett
Tel 416 469 8000
Fax 416 469 8056
Cel 416 587 1415
the engine and HP is...
but
an Elite though (or if you have that in the Rebel)...they work
great. They are a GREAT performing float that makes up for some of
the extra weight that they are in comparison to the Murphy amphibs.
(we are talking at least 160lbs heavier). I did the very first Elite
to Clamar amphib installation on the planet and know it pretty
my
struts.. ;O)
List archives located at: https://mail.dcsol.com/login username
password "builder"
by Jbcressman
Wayne Barrett...Have a Murphy amphib Rebel with 0-320 and Sensenich 74x53 (repitched from 56)
and could not be happier with T.O., climb and cruise. Bob R331
To: rebel-builders <rebel-builders@dcsol.com>
Sent: Sun, Dec 4, 2011 6:12 am
Subject: RE: [rebel-builders] Warp drive or Prince prop
Regards
Wayne Barrett
Tel 416 469 8000
Fax 416 469 8056
Cel 416 587 1415
less than his old
performance.
the right side!
Wayne O'Shea
Regards
Wayne Barrett
Tel 416 469 8000
Fax 416 469 8056
Cel 416 587 1415
