[rebel-builders] Sealing the floor question
Posted: Mon Feb 20, 2012 2:35 am
Don't use silicon anywhere... you'll never get it out of the pores to make
the paint stick to the aircraft. Every seam and overlap gets put together,
in anything I build/assemble, with WET Polyfiber EP420 just before riveting.
You definitely need a bunch of small 3/32 drain holes though, in strategic
places, in the outer bottom of the fuselage !
Sent: Thursday, November 24, 2011 8:48 PM
Subject: [rebel-builders] Sealing the floor question
Happy Thanksgiving, everyone!
I am at the point of (small drum roll, please) installing the rear floor,
and it occurs to me that any water that may leak into the cabin would run
down the rear floor, hit a seam at the interior corner wraps, and wick
under
the skin, and maybe collect in the bays beneath the floor. Has anyone used
any type of a sealant in the joint between said corner wraps and the
floor?
I have looked for a mild sealant, but the only thing that seems desirable
would be some of that strippable silicon sealant. I know that regular
silicon sealant is a pretty good glue, and I didn't want to use that. Am
fixing a problem that doesn't exist?
Tim Hickey
R808
