New web server
Posted: Mon Feb 20, 2012 2:35 am
Another quick note for those I host a website for... the new server is a Unix system... so that means the file system is case sensitive. If you name your file Default.htm, then all your code must point to Default.htm... default.htm won't work... they are seen as 2 different files. I've corrected the problems I saw as I moved things, but you might want to check your sites to make sure everything is still working.
And as it hasn't come up in a while... if there is anybody out there that would like to have a website for their project, I'd be happy to provide space on my server to host it... let me know if you're interested.
