Yes Norm.. the Elite and Rebel both use the same mounts.
The lads are looking for Conical mounts this first round and I'll take a
shot at them first as there isn't another source TTBOMK, as the factory
claims they lost the jig. The dynofocal is still available from the factory
and at least one mail list individual as well. I would name him but not sure
he's currently wanting any extra work load. If he is.. he is welcome to
speak up. I did make my jig to do both the dynofocal and conical mount, by
using bolt on inserts that attach to my 600lb tool and die / welding table.
I'm not building these on a sheet of plywood.
Norm, Marc...
As for cost, I won't be able to nail that down until I've got my steel in
hand and at least get one done to see how many hours go into it. I'm told
4130 tube is/has gone up over 4 times in price because Dillisburg has shut
down sales operations and with him gone, other supply houses will be looking
for smaller production runs and fewer mills are willing to make it .. the
price is going thru the roof.
If I get some made I'll leave it to the builder to source their own Lord
mounts unless they really want me to supply them. No point in me having to
mark up the cost to cover my time, etc. The dynafocal mount uses the Barry
Mount 94150-40 and the Conical should be used with the solid insert
aerobatic rubbers J-6230-1 and they are EXPENSIVE! I bought some from
Leavens many moons ago and they were the + side of $165 each x 4. Aircraft
Spruce currently lists them at $127.95 each Cdn x 4 required for install.
Marc...
Nose bowl, there are many that work nice. Piper bowl MC-3A has starter bump,
MC-3B has no starter bump and some other guys like the Thorpe T18 bowl =
MC-4
NormIsler@aol.com>
To: <
rebel-builders@dcsol.com>
Sent: Monday, November 21, 2011 3:43 PM
Subject: Re: [rebel-builders] 0320 conical mount
Not sure if I can actually spend the $ at this time, but curious...
Will same mount fit an Elite?
Will same mount fit 320 / 360?
Approximate cost if above scores at least a 50% yes score.
Hope you did some "catching" as well as "fishing"!
All best!
Norm
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
mike.davis@dcsol.com
Unsubscribe:
List administrator:
