Your following message has been delivered to the 183 members of
the list murphy-rebel@dcsol.com at 18:33:31 on 16 Feb 2001.
FWIW, my Scott 3200 has always required a little extra momentum (read speed
and quick brake application) to get it to kick out. After 5 1/2 years (about
300 hours of use, which would amount to at least 1200 kick outs on my strip)
it kicks some what easier but still doesn't kick really easy, which is a
GOOD THING in my opinion! When pushing my Rebel around by hand, on gravel,
the tail wheel will still not kick out unless you push down on the tailcone
(and sideways at the same time) in a quick shove (at this point it is
definitely a pain in the ass!)
One big reason that the Scott doesn't kick as easy on the Rebel, as other
aircraft that use it, is because of the tail weight or should I say lack of
it on a Rebel. The tail weight on most Rebels is only in the 50 to 60 pound
range. I threw my back out last winter when I went to help my neighbour lift
his North Star (super cub clone) tail around for him. Just thought I would
grab it and throw it around like my Rebel, while he got in. I grabbed the
tail to lift it up and instead I went down into the snow. He then helped on
the other side and I know we were both lifting more than 70 pounds a piece!
Regards,
Sent: Friday, February 16, 2001 5:50 PM
Subject: Re: Rebel Questions
too,Hi Jim !
It's not unusual to take quite a while to break in the Scott
tailwheels - it's not just the hours, it's the number of times it
gets 'cycled' ... but it could take up to 100 hrs to really loosen
up.
Maybe you should take it off & clamp it in a vise to break
it loose several times to wear it a bit. It <does> sound a bit
tougher than usual, though. Is the support shaft completely vertical ??
Are you using the springs that Scott supply ? They do seem to
work better if the springs are a bit loose ... It might be that the
internal spring that locks it is a bit too strong - is there a
friendly AME you could have check it out ??
-----------------------------orig.------------------------------------
At 07:57 PM 2/16/01 +0000, you wrote:<html><head></head><body>I've been having a swiveling tailwheel problem
I'vebut not with Murphy's tailwheel. I have a new Scott 3200, which has been
pretty reluctant to break loose and swivel ever since I installed it.
problem.had the same model tailwheel on three previous planes, with no such
haveplanes, so I wasThese all had quite a few hours on them before I got thehoping the new one would "break in" or loosen up after a few hours. I
around25 hours and still have to crawl out and shove the plane
theto gettaxiing, takeinto tight spots. (The ground handling is great for straight off and landing). I've tried low temp. grease, adjusting the tension on
puttingsprings, etc, but the thing still just turns to the steerable limits and
skids unless you physically kick it loose. I'm sure this is probably
andthat the kind of side loads on the tail section that have been causing cracks
& wrinkles. I did double up on the (Fus.30?) tail wrap, and don't see
any signs of stress yet. I don't see anything in the parts diagrambefore<br>indicates any kind of internal adjustment.<br>
<br>
I'd appreciate any suggestions from anybody that's run into this problemlooking like<br>
Thanks<br>
<br>
Jim Callahan<br>
Rebel #180R<br>
<br>
<br>
<br>
<br>
Rick Harper wrote:<br>
<blockquote type="cite" cite="mid:004401c09814$b0be4000$09020c3f@rjwh">
<div><font size="2"><em>G'day everyone from sunny Oz</em></font></div>
<div><font size="2"><em>Rick & Wendy Harper here with our Rebelissue oftaking to the skies around</em></font></div>
<div><font size="2"><em>April(ish). We just received our Decemberthe Rebel Rouser magazine</em></font></div>
<div><font size="2"><em>which has prompted the following
questions:</em></font></div>
<div><font size="2"><em>1. WHO is going to take over
feelcontinue the running of the Rebel Rouser</em></font></div>
<div><em><font size="2"> magazine? I really
pointsthis is avital service to many builders and personally have found many tips,
often&opinions very useful during our construction (items I might add quite
weconsensus fromnever heard of on the internet).</font></em></div>
<div> </div>
<div><font size="2"><em>2. What is the generalhandling?</em></font></div>all you flying Rebels out there in regards to ground<div><font size="2"><em>IE: What's the best way to go. Do
somefit someof Gordon Mohr's recessing handles into the tail section or do we make up
tosort of clamping steering handle for the tailwheel? We would love
hisknowYOUR opinions.</em></font></div>
<div> </div>
<div><font size="2"><em>3. Drew Dalgleish states in
ifletterpeople"I use the MAM stock tailwheel with my Rebel which I have heard a lot ofgreat forcriticise. I did the return release mod. and it works absolutelyMOD?</em></font></div>me".</em></font></div>
<div><font size="2"><em>WHAT THE HELL IS THE TURN RELEASE541R</em></font></div><div> </div>
<div><font size="2"><em>All opinions and advice gratefully
received.</em></font></div>
<div> </div>
<div><font size="2"><em>Rick & Wendy Harper...Rebel<div> </div>
<div><font size="2"><em>PS: Steve Sloan 536R asked in the Rouser
someanyonehad fitted a tailwheel and spring</em></font></div>
<div><font size="2"><em>fairing...we have. I'll send you
*---------------------------------------------------------------------------pic's as*--------------------------------------------------------------------------soon as I find WHERE I put 'em !</em></font></div>
</blockquote>
<br>
</body></html>
---------**--------------------------------------------------------------------------Contributors' page at:
Visit the book store at:
*---------------------------------------------------------------------------Contributors' page at:
