Rebel Questions
Posted: Fri Feb 17, 2012 8:40 pm
In a message dated 2/16/01 6:35:37 AM Central Standard Time,
rjwh@ozemail.com.au writes:
Rick&Wendy
GET the full swiveling mod no ifs and or buts about it! It takes a green acre
to turn around if you don't have it. And puts a lot more stress on you're
tail wheel spring and control horn. With the full swiveling tail wheel it
stays locked in [ full rudder motion] but will break loose if you need to
turn more, like taxiing when you need to lock up one brake and turn on one
wheel. It will actually turn around in 360 deg. on one wheel
Then when you straighten out and pull forward a bit it will swivel back and
lock back in to [ full rudder motion only]. You wont know it's there in
landing. Unless you ground loop it real bad and then it might just save some
damage on the tail wheel assembly. Never really found landings a problem.
Phil&Lisa Smith #460 N414D
WHAT THE HELL IS THE TURN RELEASE MOD?
Rick&Wendy
