[rebel-builders] #5 Hinge Rear spar for wing Super Rebel/Moo
Ted Waltman
[rebel-builders] #5 Hinge Rear spar for wing Super Rebel/Moose Upgrade
Post by Ted Waltman » Sun Feb 19, 2012 11:34 pm
Great suggestions, Dick & Eric. Alas, even though I used a laser, on one
wing, I had to add maybe an 0.032" shim on the outboard hinge when I went to
mount the ailerons for good.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Dick
Wampach
Sent: Saturday, November 05, 2011 12:21 PM
Subject: RE: [rebel-builders] #5 Hinge Rear spar for wing Super Rebel/Moose
Upgrade
Paul, Do what you must do to have all hinge points aligned, the less
friction or bending the better.
I used a laser pointer up against the inboard end to test that, A piece of
string stretched out tightly would also work.
Doing the math is a good starting point, but the actual alignment is the
proof!
Dick Wampach SR-108 N331RW
paul.lennemann@dcsol.com
Sent: Saturday, November 05, 2011 10:46 AM
Subject: [rebel-builders] #5 Hinge Rear spar for wing Super Rebel/Moose
Upgrade
I am beginning to pre-build the rear spar in my head. Does the #5 hinge
(wing tip hinge) need to be shimmed to be in the correct position to
minimize/prevent binding. It seem that the hinge will be pulled forward to
the main spar extentions, based on adding up the part thicknesses. Or am I
over
analyzing?
I appreciated the discussion regarding the electrical conduit last time I
posted a question.
Paul Lennemann SR 074
