[rebel-builders] matco brake caliper seal
Garry Wright
Post by Garry Wright » Sun Feb 19, 2012 11:34 pm
I haven't done the ones on the floats, but I did do the wheel gear. I just
took the o-ring to Parts-R-Us and found the same thing there. After
cleaning up the cylinder and piston it worked fine.
Garry
On Sat, Oct 29, 2011 at 3:04 PM, Drew Dalgleish <drewjan@cabletv.on.ca>wrote:
Has anyone had to replace their wheel caliper o-ring. Mines leaking and
I wonder if it's an off the shelf part or something that I have to order
from Matco.If as I suspect it's a standard part is it imperial or metric
size?
drewjan
Post by drewjan » Sun Feb 19, 2012 11:34 pm
Thanks Gary and Dick Yes it's my wheel gear brakes that are leaking. My floats have cleveland wheels and brakes.
Sender: mike.davis@dcsol.com
Date: Sat, 29 Oct 2011 18:29:47
Subject: Re: [rebel-builders] matco brake caliper seal
Garry
size?
N.Smith
Post by N.Smith » Sun Feb 19, 2012 11:34 pm
Hi Drew
I bought the following set off ebay a couple of months ago (I think the item
is still active)
High QuaIity imperial O Ring Seal Kit 382 Piece
Item Number 140586153714
There was one size in the set that was a match and sorted a slow leak I had
on my JDM caliper.
Nig
745E
Dalgleish
Sent: 29 October 2011 22:04
Subject: [rebel-builders] matco brake caliper seal
Has anyone had to replace their wheel caliper o-ring. Mines leaking and I
wonder if it's an off the shelf part or something that I have to order from
Matco.If as I suspect it's a standard part is it imperial or metric size?
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.1834 / Virus Database: 2092/4582 - Release Date: 10/29/11
Post by Ken » Sun Feb 19, 2012 11:34 pm
I presume everyone smooths the cylinder bore when replacing o-rings. I
just use around 300 or 400 wet sandpaper. So far I've not seen metric
o-rings in any of this stuff. If I don't have the correct o-ring in
stock, in Canada 'Rubberline' is my first choice for 0-rings, 'Spaenaur'
next. Standard common buna o-rings in assortments from places like
'princess auto' or a farm supply work just fine for oil but the
assortments seldom have ones large enough for calipers.
There have been a few cases where due to excessive wear or incorrect
parts the piston has extended too far causing leaks but I'd expect quick
loss of all the fluid if that was the situation.
On 30/10/2011 6:04 AM, N.Smith wrote:
Hi Drew
is still active)
on my JDM caliper.
Nig
745E
Dalgleish
David A. Ricker
Post by David A. Ricker » Sun Feb 19, 2012 11:34 pm
As general source you can find O-rings at local places that repair
hydraulic cylinders and industrial suppliers. If McMaster Carr will
deal with you they will have them. I'm not too keen on the Princess
Auto level of quality for something like this.
If you're using automotive brake fluid you want EPDM material, otherwise
the typical Buna-N/Nitrile is probably the choice if you're using
MIL-H-5606.
This:
http://www.efunda.com/designstandards/o ... MIL-H-5606
is a good on-line look-up for fluid compatibility.
Elite583 and nowhere near doing brakes :-(
Hi Drew
is still active)
on my JDM caliper.
Nig
745E
Dalgleish
