[rebel-builders] Needed Position Light Parts
drewjan
Post by drewjan » Sun Feb 19, 2012 11:34 pm
WHat brand are your lights Jerry. I have some grimes parts that you can Have.
Sender: mike.davis@dcsol.com
Date: Fri, 14 Oct 2011 15:21:24
Subject: [rebel-builders] Needed Position Light Parts
At Sun-N-Fun this year, I purchased a used set of position/tail lights in
the tent. My plan was to use the PSA Enterprises LED replacement lenses for
a simple LED lighting system on my Murphy Super Rebel. When I got home, one
of the lights had no guts, i.e. the spring, phenolic washer, plastic washer,
wood spacer, and metal center pin. Before I hit the salvage yards, does
anyone have a single light or light parts laying around? I just need the
guts - WTB. I suppose I could machine the parts as well - probably not to
difficult other than time. Lesson learned, beware of parts in sealed bags.
SR2500 #093
www.mykitlog.com/jfolkerts
Jerald Folkerts
Post by Jerald Folkerts » Sun Feb 19, 2012 11:34 pm
Thanks. The light base is a Grimes Cage 72914. What I need are the guts --
a phenolic washer, a metal power lead attach (small cylinder with hole in
middle), plastic washer, a wood or rubber turned block to hold the metal
power lead attach, and a spring. OK to call me at 314-791-3536 or write
jfolkerts1@gmail.com.
drewjan@cabletv.on.ca
Sent: Saturday, October 15, 2011 10:28 AM
Subject: Re: [rebel-builders] Needed Position Light Parts
Have.
SR2500 #093
