are happy with them. Auto gas being a lower octane should give you more
power and fuel economy, not less. You can tell if there is alcohol in the
gas by putting some in a glass jar with a few drops of water. If the water
is absorbed there is alcohol. The problem with alcohol is that it will
deteriorate some rubber hoses and carburetor parts. You have to be sure you
use parts that are compatible. Also the wet wings are a problem. I put
some of the sloshing compound that I had used in a jar of alcohol and it
softened. I would want to check with the manufacturer of the pro-seal you
used as well. A friend has used auto gas in his cherokee 140 for years and
swears it runs better and smoother than avgas. He does fill about every
third tank with avgas to maintain the lead coating on the valves that
aircraft engines need for lubrication. I intend to use avgas but I'm also
using a Subaru engine.
Regards, Gordon Mohr
Sent: Tuesday, February 13, 2001 5:52 AM
Subject: Re: Aero Sport Air / electronic ignitions
beWe are about to order a Lycoming O-360 engine and have had good reports
about Aero Sport Air in Kamloops, BC. They are a rebuilder of non
certified engines. Much as I would like "new" it just isn't in the cards
at US$25K +. Has anyone had experience with Aero Sport (either good or
bad).
Also, they have available the Laser ignition which is STC'd for certified
engines or Lightspeed or Electroair ignitions. The Laser is $1300 and the
Lightspeed or Electroair $500. Any comments on these ignitions as to
function, best value, trouble shooting, and parts availability? We will
todoing a lot of backcountry mountain flying in Montana and Idaho and
reliability is foremost.
Finally, for auto gas use Aero sport uses 7.5:1 pistons. Any reason not
*---------------------------------------------------------------------------go the auto gas route? I know there will be some HP loss and/or increased
fuel burn. How critical is it that fuel contain NO alchohol? Some of the
US western states use alchohol in all the autogas I've seen while
traveling.
Ralph Baker / Sue Scouten
Elite 611E
To: rbaker@sumter.net
Subject: murphy-rebel Digest for 12 Feb 2001
Date: Tuesday, February 13, 2001 12:00 AM
*-----------------------------------------------------------------------------------*Contributors' page at:
Visit the book store at:
goal--------*--------------------------------------------------------------------------murphy-rebel Digest for 12 Feb 2001
Topics covered in this issue include:
1: New guy questions
by "Ralph Baker" <rbaker@sumter.net>
2: fus-7 and carry-through
by "Jones, Mike" <MJones@hatch.ca>
3: instruments
4: Re: instruments
by Richard DeCiero <rsdec1@star.net>
5: Re: instruments
by Bob Patterson <apat@istar.ca>
6: fus-7 and carry-through
7: test
by "J. E. Callahan" <jecall@alaska.net>
8: test
9: test
10: Re: test
by LisaFly99@aol.com
11 Message:0001
--------------------------------------------------------------------------orFrom: "Ralph Baker" <rbaker@sumter.net>
Subject: New guy questions
We are first time builders on Elite 611E so I guess entitled to at least
$.01 worth. I suggest the following:
You CAN do it with a moderate skill level. No need to be a tool makerdrillengineer.
The Murphy quality is excellent with jigless assembly.
Although the tool list is not great there are some necessities. I
suggest for power tools:
4" table mounted belt sander.
1/2" capacity, 1/2HP bench drill press.
5HP air compressor. (Check for max CFM as they vary quite a bit)
Air powered rivet puller. (Should cost about $90)
Air die grinder with 3" aluminum cutoff discs.
Dremel variable speed hand tool.
General hand tools also are required. I would include a right angleusualattachment, hand nibbler, fly cutter, hand seamer, in addition to thepublicationclecos, cleco pliers and drill bits. Don't try to do quality work with
improper tools. (And don't ask how I know.) Get a copy of FAAseriesC37.13, Approved Methods of Alteration and Repair and Tony BingelisRealizeof 4 books on homebuilding (available from EAA). Be sure you have the
family approval and support of the project both in time and cost.willit is like eating an elephant and it is one bite at a time. Actually I
find it helpful to look at construction as a series of small projects to
avoid the "overwhelmed" sense. Also, we have not set a time line. Itsomethingtake as long as it takes to do the best quality job we are capable of.
Darryl has been quoted as saying "it's not a rolex watch" and inevitably
there will be some places you are not as proud of. Do not lower the
quality goal, and never compromise a structural area. Try to doevery day. Join EAA and utilize the resources available such as this
group. Don't build just to fly, enjoy the building process with the
Siouxassemblingof being able to say "yes, I built it myself". A good start ispricesthe printed material including what I have referenced above and the
catalogs such as Aircraft Spruce and Aircraft Tool Supply Co. Checkas they vary considerably. One tool I did not mention above is our
ofbit.brand 3600 rpm 1/4" chuck drills. These are about $200 and worth every
penny. Another is an electric screwdriver with single flute deburringthanSusan, the Deburring Queen, would probably give up her BMW motorcycleeither of those tools.
This has gotten a little long but I hope you feel it is useful as most
theirthatwhat is on the list is for those who are already immersed. I can sayifI enjoy going out to our hangar every day to work on what will be N624E
before the end of the year. Please feel free to contact me off the list--------------------------------------------------------------------------you wish.
22 Message:0002
--------------------------------------------------------------------------theFrom: "Jones, Mike" <MJones@hatch.ca>
To: "'murphy-rebel@dcsol.com'" <murphy-rebel@dcsol.com>
Subject: fus-7 and carry-through
Hi All
Looking at fitting the forward cage together and can't seem to tell inmanal if the fus-7 (bottom front panel) overlaps both bottom main carry
throughs or just the forward most one. ???????? Can someone look at
--------------------------------------------------------------------------rebel and let me know.
regards
Mike#007
33 Message:0003
forOtherFrom: "Jones, Mike" <MJones@hatch.ca>
Subject: instruments
Hi all
I am consider instrumet choices now and am looking at electric vs vac.each,than cost of electric can anyone offer ideas about the pros & cons of--------------------------------------------------------------------------maintenance of vac system etc.
regards
Mike#007
44 Message:0004
--------------------------------------------------------------------------articles. He is veryFrom: Richard DeCiero <rsdec1@star.net>
To: " (Murphy Rebel Builders List)" <murphy-rebel@dcsol.com>
Subject: Re: instruments
Mike,
Go to www.aeroelectric.com and read some of Bob Nuckoll'sredundantpositive on all electric a/c and offers several interesting thoughts andelectrical system requirements for an all electric a/c. At this point
*---------------------------------------------------------------------------my rebel I aminstruments). I willgoing to leave out the attitude indicator and the DG (the two vacuumis way up there.probably end up with electric gyro's for these two even though the costcoordinator willMaybe I'll buy 1 per year once I get the darned thing flying. The turnventuri'sbe installed now.
I cannot get excited about using vacuum pump systems. You could useelectric systeminstead of a pump. In the short run the costs are probably more for thedone abut I feel the reliability of the electrics are worth it but I have notavailable fromcomparison. There are imported electric gyro's (about $1000.00 ea)Otheraircraft spruce and specialty. I just saw them in their new catalog.
Good luck.
Rick D.
Jones, Mike wrote:
Hi all
I am consider instrumet choices now and am looking at electric vs vac.each,than cost of electric can anyone offer ideas about the pros & cons ofmaintenance of vac system etc.
regards
Mike#007
--------------------------------------------------------------------------55 Message:0005
--------------------------------------------------------------------------------------------------------------orig.---------------------------------To: <murphy-rebel@dcsol.com> (Murphy Rebel Builders List)
Hi Mike !
The new vacuum pumps are <supposedly> MUCH lower maintenance,
but they DO take a few horsepower, ALL the time ! Venturis would be
low maintenance, but a bit of extra drag. Older vacuum pumps required
major work every 300 hours or so, and were pricey to fix. Some -
(the 'wet' type) could cause horrible oil leaks very quickly !
Be careful with vacuum instruments - there are <different> types
for vacuum pump or venturi ! The venturi instruments must be very
good quality, as they get less, and more variable, suction ....
Electric is a good way to go, but expensive. You really have
to decide what kind of flying you're going to do - unless you plan
on night flying, you don't need ANY gyros ! Save your money and go
flying NOW ! You can cut the holes, blank them, and buy the gyros
LATER, <IF> you decide you want 'em.
For night, all you need is a DG, and a turn & bank, to
be legal (likely a venturi DG, and electric T & B). <I> would
consider full IFR gyros a COMPLETE WASTE OF MONEY, <AND> a GREAT
<RISK> to your life !! Too many people TRY to fly IFR when they
are NOT current, and end up DEAD !!! IFR weather in this part
of Canada is VERY HOSTILE, and small aircraft have VERY little
chance of surviving it (ice/total white-outs !) !
If you want to fly IFR legally, you MUST have dual static,
heated pitot, AND the whole system must be re-certified ANNUALLY !
No IFR is allowed until the 25 hours have been flown off, in any
case.
If you do get gyros, you will want to mount them on a
separate panel with shock mounts to reduce the vibration.
carryOtherAt 11:53 AM 2/12/01 -0500, you wrote:Hi all
I am consider instrumet choices now and am looking at electric vs vac.each,than cost of electric can anyone offer ideas about the pros & cons of*--------------------------------------------------------------------------maintenance of vac system etc.
regards
Mike#007
66 Message:0006
--------------------------------------------------------------------------theFrom: "Wayne G. O'Shea" <oifa@irishfield.on.ca>
Subject: Re: fus-7 and carry-through
BOTH MIKE!!!
www.irishfield.on.ca.
Sent: Monday, February 12, 2001 11:49 AM
Hi All
*---------------------------------------------------------------------------theirthroughs or just the forward most one. ???????? Can someone look atrebel and let me know.
regards
Mike#007
77 Message:0007
----------------------------------------------------------------------------------------------------------------------------------------------------From: "J. E. Callahan" <jecall@alaska.net>
Subject: test
<html><head></head><body><br>
</body></html>
88 Message:0008
Subject: test
99 Message:0009
To: "murphy-rebel@dcsol.com" <murphy-rebel@dcsol.com>
Subject: test
1010 Message:0010
--------------------------------------------------------------------------From: LisaFly99@aol.com
Subject: Re: test
--part1_40.759bae8.27ba0d12_boundary
Content-Type: text/plain; charset="US-ASCII"
J.E.
you're coming in load and clear on this end!
Content-Type: text/html; charset="US-ASCII"
<HTML><FONT FACE=arial,helvetica><FONT SIZE=2>J.E.
<BR>you're coming in load and clear on this end!</FONT></HTML>
--part1_40.759bae8.27ba0d12_boundary--
*---------------------------------------------------------------------------Contributors' page at:
