[rebel-builders] Tail wheel for Super Rebel or Murphy Yukon
Post by Drew Dalgleish » Sun Feb 19, 2012 8:55 pm
I built one for my rebel and am very pleased with it. You can get plans
from Bob Barrows ( the bearhawk designer ) for $25 and modify it to suit
your needs.
On 06/09/2011 9:00 PM, Reid Huzzey wrote:
I am looking at purchasing the Iron Design 3.5 X 10" wheel for my kit.
I did not get the Outback Tail kit, that I purchased from Murphy Aircraft in July 2007 for $563.00, so need to find a suitable replacement. I have researched the following providers which are more money, also because some are for certified aircraft.
XP Modification 500 X 5 for $1700.00
Alaskan Bushwheel ABI-3200 4 X 8" $1025.00
ABI-3400 $1550.00
Scott 3400 similar to above
Alaska Tundra 4X4 $750
Now the Iron Design seems to be a reasonably priced option at $656.00
My stinger is 1" in diameter and the mounting is the same as the Super Rebel, and maybe the Moose.
The Iron Design stinger mount is 3/4" diameter. I could get the 3" at the wheel mount end machined down to 3/4". The angle that the rod stinger goes into the tail wheel is normally manufactured at 15 degrees. Then the king pin should be vertical or slightly toe ahead at full gross weight.
Does anyone have experience with this tailwheel?
Any one know what the angle is on the Murphy designed tail wheels?
Advice is most appreciated, better alternatives or do you think this will work?
Reid
Yukon # 0013
Post by snowyriver » Sun Feb 19, 2012 8:55 pm
I have the 8" version on my rebel, it uses a flat spring. Very limited
time (4.4 hrs!!) but so far it works well with no noticed shimmy. I do
have 2 addn'l hrs taxiing with it and found that I like the handling
better with a slight slack in the chains. Craig
ABI-3400 $1550.00
full gross weight.
will work?
Reid Yukon # 0013
Bob Andrews
Post by Bob Andrews » Sun Feb 19, 2012 8:55 pm
Reid,
I have a heavy duty tail wheel that's never been used ... only problem is
that it's in my shop in Idaho, and I won't be back there for a few weeks.
If you haven't found a solution by then, shoot me an email ...
robert@montanasky.us ... I'll send you a picture of it, and we'll work out a
price that works for both of us.
Cheers, Bob 612e
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Reid
Huzzey
Sent: Tuesday, September 06, 2011 6:00 PM
To: rebel-builders-d@dcsol.com
Subject: [rebel-builders] Tail wheel for Super Rebel or Murphy Yukon
ABI-3400 $1550.00
work?
Reid
Yukon # 0013
Ted Waltman
Post by Ted Waltman » Sun Feb 19, 2012 8:55 pm
Reid,
I have the 3450 AK Bushwheel and really like it.
You have one more issue to think about though. The swivel-stinger mount
bolts on the Murphy installation are (IIRC) 1 3/16" center-to-center whereas
every other manufacturer that I know of (e.g. Scott, AK Bushwheel, etc) use
1 1/4" center-to-center holes. Hence if your stinger already has holes
drilled you'll have to fill them (weld?) or add bushings or (?) and redrill
them.
Huzzey
Sent: Tuesday, September 06, 2011 7:00 PM
ABI-3400 $1550.00
work?
Reid
Yukon # 0013
rhuzzey
Post by rhuzzey » Sun Feb 19, 2012 8:55 pm
Thanks Ted,
My stinger is not drilled for the holes. But it is 1"diameter at the last 3" then tapers some but continues through the tail as 1".
Do you know what the normal angle for the stinger to the horizontal of the tail wheel bearing?
Reid
Sent from my iPad
On 2011-09-07, at 6:15 AM, "Ted Waltman" <ted@vafm.org> wrote:
Reid,
them.
Huzzey
ABI-3400 $1550.00
work?
Reid
Yukon # 0013
rhuzzey
Bob thanks,
I will consider that, do you know the diameter of the stinger mount.
What make of heavy duty tail wheel is that?
I will wait for the pictures and measurements, thanks again.
Reid
Sent from my iPad
On 2011-09-06, at 10:24 PM, "Bob Andrews" <robert@montanasky.us> wrote:
Reid,
Cheers, Bob 612e
Huzzey
ABI-3400 $1550.00
work?
Reid
Yukon # 0013
rhuzzey
Thanks Craig, I have not heard any negative co mets about Iron Design tail wheels.
still evaluating and Scott was sending me some more measurement information on his mounting bracket and wheel.
Reid
Sent from my iPad
ABI-3400 $1550.00
full gross weight.
will work?
Reid Yukon # 0013
rhuzzey
Hi Drew
I have already made too many parts in my mind unneccesarily.
I only have a band saw and drill press, so not up to anything to complex.
Reid
Sent from my iPad
your needs.
ABI-3400 $1550.00
Reid
Yukon # 0013
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 8:55 pm
I have 157 hrs. on the 8" Iron Design tailwheel. Love it.
Ron
254R
wheels.
Reid
Sent from my iPad
Ted Waltman
Reid,
I'm not sure what "normal" is as such depends on tire sizes, but I believe
most folks might have the stinger mounted in the 2nd hole up from the
bottom. Start there and evaluate the angle of your swivel bolt.
rhuzzey@telus.net
Sent: Wednesday, September 07, 2011 8:35 PM
Subject: Re: [rebel-builders] Tail wheel for Super Rebel or Murphy Yukon
Thanks Ted,
tail wheel bearing?
Reid
Sent from my iPad
Reid,
whereas
use
redrill
them.
Huzzey
in
ABI-3400 $1550.00
goes
work?
Reid
Yukon # 0013
