[rebel-builders] Rudder cable lube ?
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:54 pm
Nig.. I don't like adding oil or grease to nylon guide areas. Silicon spray
will help and not collect dirt/grit like oil will.
Sent: Saturday, August 27, 2011 2:29 PM
Subject: [rebel-builders] Rudder cable lube ?
Hi All
Ia anyone using any kind of grease or similar to reduce friction on the
rudder cables as they pass through the cable guide RG-1's ?
Ta
Nig
745E
N.Smith
Post by N.Smith » Sun Feb 19, 2012 11:54 pm
Thanks Wayne
Nig
G. O'Shea
Sent: 27 August 2011 21:16
Subject: Re: [rebel-builders] Rudder cable lube ?
Hi All
Ta
Nig
745E
Anytime....
Iif you happen to be thru Hullavington this week, Murray is at the Barrass's
on the edge of town. Only place with a Herc weather vane!
Sent: Saturday, August 27, 2011 4:31 PM
Subject: RE: [rebel-builders] Rudder cable lube ?
Thanks Wayne
Nig
G. O'Shea
spray
Hi All
Ta
Nig
745E
