[rebel-builders] Repeat email
Posted: Sun Feb 19, 2012 11:54 pm
Thanks Mike.. I'll get Daryl to have a look from this end as well (at his
server in gbay plastics) when he gets back from holidays.
Sent: Wednesday, August 17, 2011 11:34 AM
Subject: [rebel-builders] Repeat email
Wayne,
Spent some time going through the server logs this morning, and there are
4
addresses that my system keeps attempting to send/resend messages to...
oifa@irishfield.on.ca
doshea@georgianbayplastics.com
So here are yours... and Daryl's I assume. Anyway, both of yours being on
the same server I am seeing exactly the same thing... which is what's
strange. The log shows that the message was delivered and accepted, but
then the system attempts to resend the same message an hour later. I've
copied these log entries and sent them in to the developer for review.
schmidt@mtaonline.net
dazey@turbousa.com
Now these two at least make sense, since the message is not being accepted
correctly by their server, so they should be queued to resend. But...
they
are also both on the same server (not same as you, but same as each
other),
and they are the only list members on this server... so I would think
there
must be a problem with their server.
Sent: Tuesday, August 16, 2011 6:40 PM
Subject: Re: [rebel-builders] Re: [rebel-builders] Rebel tail strut fork
ends - IMPORTANT !!!
Okay.. so skip my last message Mike.. here is Jesse's coming for the
third
time from his smartphone
Sent: Tuesday, August 16, 2011 9:29 PM
Subject: [rebel-builders] Re: [rebel-builders] Rebel tail strut fork
ends -
IMPORTANT !!!
I had an interference issue there and had to take out some additional
material from the angle. I can see how that could be a common occurance
since it is up to the builder to make that part and I have also noticed
that side to side rocking of the fuselage will cause that whole assembly
flex laterally. If the angle was in contact with the inner surface of the
strut fork, that might cause a failure. I'm not sure how to stop that
lateral flex. I was considering remaking the fittings that bolt to the
side
of the fin post (ts 3?) Out of steel.
Sent from my Verizon Wireless 4GLTE smartphone
----- Reply message -----
Subject: [rebel-builders] Rebel tail strut fork ends - IMPORTANT !!!
Date: Tue, Aug 16, 2011 3:39 pm
Okay.. so attachement at the "man made" end (vs factory made stab
attach).
Maybe they have an interference issue.. the attachment angle hasn't been
relieved enough and is bottoming in the fork just as the bolt makes the
hole. Or a bad tail spring set up with a lot of movement working the
angle/fork fitting. Maybe I should jump on a pressurized can and come
check
it out in person. I could use a pint of 6X from a good UK pub !!
:O)
Sent: Tuesday, August 16, 2011 12:50 PM
Subject: RE: [rebel-builders] Rebel tail strut fork ends - IMPORTANT !!!
BTW... it's only certain senders that emails repeat from. My own have never
repeated, nor Ken Lehman's, Nigel or others. The repeats come off Jesse,
Doug Farrow and Rick Greenwood mainly...and was curious if it was a
smartphone issue?
Sent: Wednesday, August 17, 2011 1:27 PM
Subject: Re: [rebel-builders] Repeat email
Wayne,
4
on
dazey@turbousa.com
accepted
they
other),
there
third
ends -
IMPORTANT !!!
by Mike Davis
Interesting... I'll include that information for the developer.
Sent: Wednesday, August 17, 2011 9:43 AM
never
smartphone issue?
Wayne,
are
4
on
dazey@turbousa.com
accepted
they
other),
there
by Toni Schmidt
Mike, I'm travelling in Europe and recently checked my mails and, yes, I
get the same group of 10 or 12 mails repeated over and over. Deleted some
300 so far. I'm not computer savvy and have no idea what causes it, but only
mails from the rebel-builders' site are repeated, none of the others. But
out of my experience, MTA needs to be kicked once in a while.
Hope to get back to building on my Rebel sometime in September.
Thanks for your work, Toni
by wang
Mike are you running several servers with one perhaps being the "domain
controller"? I think this is where your problem might be, duplicates...
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]
Sent: August 17, 2011 11:35 AM
Wayne,
Spent some time going through the server logs this morning, and there are 4
dazey@turbousa.com
correctly by their server, so they should be queued to resend. But... they
are also both on the same server (not same as you, but same as each other),
and they are the only list members on this server... so I would think there
Okay.. so skip my last message Mike.. here is Jesse's coming for the third
ends -
IMPORTANT !!!
side
attach).
check
:O)
Hi Wayne (and all)
The fork that broke was the lower end (fuselage end) on this latest one.
I'm
trying to find out more about the original event.
Aircraft was a 235 powered one so not excessive power as a cause.
Nig
G. O'Shea
Sent: 15 August 2011 23:03
Subject: Re: [rebel-builders] Rebel tail strut fork ends - IMPORTANT !!!
Also curious... Nigel is it the upper attachement at the stab or the
lower
attachement at the tailspring angle that broke on these two UK birds??
I cleaned and inspected all of mine today with a "fine tooth comb". No
issues.
Sent: Monday, August 15, 2011 5:48 PM
by Mike Davis
Wildcat! Interactive Net Server is an application that runs on Windows... it
is completely unaware of domain or active directory configurations. The
problem turned out to be the timing routine the SMTP module was using while
waiting for the remote server to respond that the transfer was complete.
Hopefully we've got it fixed... shouldn't take long to know for sure. So
far since installing the update last night I am not seeing multiple attempts
in the server logs... but there hasn't been much activity on the list since
the update, so I'm not convinced yet. ;-)
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of wang
Sent: Wednesday, August 17, 2011 9:08 PM
Subject: RE: [rebel-builders] Repeat email
Wayne,
dazey@turbousa.com
ends -
IMPORTANT !!!
side
attach).
check
:O)
Hi Wayne (and all)
I'm
Nig
G. O'Shea
lower
issues.
Thanks Mike.. I got Toni's email 6 times since 7:30pm yesterday. Hopefully
you've now got the fix in place and we're good to go again!
Sent: Thursday, August 18, 2011 9:41 AM
it
while
attempts
since
Wayne,
4
dazey@turbousa.com
they
other),
there
third
ends -
IMPORTANT !!!
side
attach).
check
:O)
