[rebel-builders] Re: [rebel-builders] Bent gear leg
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:54 pm
They bend once... then they snap! Most don't catch the bend first and glad
you did !
To be sure it's identical to what you have.. cut your own from 1.25 x 1.25
square x 0.125 6061-T6 tube, that you should be able to source from someone
there in the State.
That said.. didn't you build your own legs or was that someone else I've got
you mixed up with!?!
Sent: Monday, August 15, 2011 2:15 PM
Subject: [rebel-builders] Re: [rebel-builders] Bent gear leg
Ok, what is the best way to get parts these days? Bob P?
----- Reply message -----
Subject: [rebel-builders] Bent gear leg
Date: Mon, Aug 15, 2011 10:27 am
Replace! (Sorry) ! ;O)
Sent: Monday, August 15, 2011 12:09 PM
I had a hard landing which bent a gear leg (bungee style with die
springs).
I have been landing at some pretty challenging spots in the Idaho
backcountry while feeling out the short/rough capabilities of the Rebel.
Well I guess I found the edge of the envelope: I put her down on a 700'
rough rocky strip with trees, at 4,000' elevation. I knew I had to plant
it
right on the end, and plant it I did. I was already aware of the tendency
of that wing to maintain its rate of decent in the flare regardless of
increasing aoa. I knew I would need to add power to arrest the descent,
but
I guess the shortness of the strip influenced my reflexes. Anyway, I hit
pretty hard. I looked it over really good, and then went fishing. Only
after really getting down on the ground and looking carefully, a week
later, did I notice a bent gear leg.
Has anyone had success with trying to straighten one, or will I need to
replace it? I was thinking I could put it in a press with some blocks of
wood and tweak it back into shape. Seems like it will be a pain to
replace..will have to basically take the whole gear assembly apart.
Anyway, I will probably keep flying for the rest of the summer. Some 29"
bushwheels will be on my shopping list if I'm going to do any more strips
like that, and VGs. Will VGs help with the "falling out of the sky"
characteristic? Doesn't seem like the best stol airfoil, maybe that's why
Angus came up with the LE cuff. As someone said ...sto...but not L. Seems
like it needs more flap too. If you look a Twin Otter which I think has
the same airfoil, it has a ton of flap. It still falls out from under you
if you're not carefull though. I have often wondered why Dehav. used that
airfoil, and I guess it can be used to a pilots advantage in precise
touchdown control with no float, but with a plane like the twotter you
can
flare it a lot more....and the gear is really, really tough....I know.
karl hipp
Post by karl hipp » Sun Feb 19, 2012 11:54 pm
with my 26 inch high tires on Kawasaki 4 wheeler running gear, the nose
sits a bunch higher. And with the vg's I am able to consistintly make
very slow perfect full stall 3 point landings. The rebel presently sits
on its 3 wheels at what seems to be the perfect angle of attack for
landing in the stall.
The big tires obviously slow me down, but I am happy to drag them around
because if I need to do an off field landing where I fly in the
mountains of western Colorado "off field" might get bumpy.
I have pulled out the noisy and unreliable Subaru 2.2 litre and will be
flying (hopefully) later this week behind an O-320 Lycoming. Just
waiting for a new spark plug wire. I figured I might as well make the
first flight with the O-320 with all cylinders at 100%.
Thanks to Bob Patterson and others who sent me pictures on how to build
the 4 door cowl.
Karl Hipp
On 8/15/2011 11:32 PM, jessejenks@hotmail.com wrote:
I may take you up on that Ben. Thanks for the offer. I don't have VGs yet, but was hoping like you that they would allow more lift during the flare. It sounds like that isn't the case though. I am finding that the airplane is controllable to a pretty slow touchdown speed, but unfortunately the only way to stop the descent is with power. I wish the gear was about a foot taller, then maybe you could use all the lift the wing is capable of producing. Actually if I can figure out how to beef up the rear attach points I may build taller gear. Maybe Wayne can modify my die spring struts...and add a second spring.
To: "rebel-builders@dcsol.com"<rebel-builders@dcsol.com>
Date: Mon, Aug 15, 2011 2:20 pm
Hey Jesse,
I found the main gear leg material a couple years ago, with the only
downside that I had to buy a 16ft (or maybe it was 20) stick. I still
have most of it left of course. Happy to cut and ship to you at cost.
IIRC, this is the 1.25" square with rounded corners, I forget wall
thickness, but I know it's exact match to MAM. I also have the smaller
square stuff used above the bow-tie.
BTW, Are you using VGs? My hope is that they soften that last drop in
phase.
-Ben
On 8/15/11 9:09 AM, "jessejenks@hotmail.com"<jessejenks@hotmail.com>
springs). I have been landing at some pretty challenging spots in the
Idaho backcountry while feeling out the short/rough capabilities of the
Rebel. Well I guess I found the edge of the envelope: I put her down on a
700' rough rocky strip with trees, at 4,000' elevation. I knew I had to
plant it right on the end, and plant it I did. I was already aware of the
tendency of that wing to maintain its rate of decent in the flare
regardless of increasing aoa. I knew I would need to add power to arrest
the descent, but I guess the shortness of the strip influenced my
reflexes. Anyway, I hit pretty hard. I looked it over really good, and
then went fishing. Only after really getting down on the ground and
looking carefully, a week later, did I notice a bent gear leg.
can flare it a lot more....and the gear is really, really tough....I know.
