[rebel-builders] Control Deflection and rigging. 578E.
Posted: Sun Feb 19, 2012 8:51 pm
by Bob Patterson
Hi Rob !
You should check the Factory Service Bulletins on the
web site, under Elite, Tech Support -- there's a manual update
there from years ago (2002 !), with the deflections in it !
http://www.pattersonaerosales.com/Aircr ... sembly.pdf
The flaps &ailerons have 5 degrees reflex built in, if you
build it by the book, with the flaps even with the top of the
fuselage (that's why the fuse top was raised on the Elite...).
bobp@prosumers.ca
bobp@pattersys.com
http://www.Pattersys.com
responsibility of the reader.
On June 29, 2011 02:53:08 am Rob Maxwel wrote:
Hi
We are about to install the final rivets in the aileron and flap
instalation and also setting the rudder and elevator on the Elite.. The
manuals we obtained from the previous builders do not appear to have any
data on the correct amount of travel for any of the control surfaces.
What control deflections are we looking for? Is there any reflex on the
flap and aileron?
Regards Rob Maxwell
578E
