[rebel-builders] Rebel Door Hinge Rivets Oooops!
Terry Dazey
Post by Terry Dazey » Sun Feb 19, 2012 8:51 pm
Ooops, correction to my last post:
I meant the rivets will be 1410's NOT 1610's.
Am at work with distractions. That is my excuse and I am sticking to it.
Terry Dazey
R662
--- dazey@TurboUSA.com wrote:
Subject: Re: [rebel-builders] Rebel Door Hinge Rivets
Date: Fri, 17 Jun 2011 09:33:26 -0700
Thank you Mike, Ken and Ron for your answers to my door hinge rivet question.
Seems the consensus is to use aluminum rivets and keep an eye on them. Yes, Ken,
those stainless rivets are a bugger to remove. Unfortunately, I did not plan, nor
did I drill any additional rivet holes at the hinge. However, the plan is to use
the standard RV1610 aluminum rivets, and if I can locate a couple of Q aluminum
rivets locally, I will use those top and bottom as Ken did.
