[rebel-builders] Rebel Door Hinge Rivets
Posted: Sun Feb 19, 2012 11:51 pm
by Ron Shannon
My 29/06/98 version of Ch. 23 specifies SS 1/8" x 1/8"... which
certainly isn't long enough. Like Ken, I didn't use SS rivets either.
Seems to me there was some discussion of this before. There must have
been because it's not the kind of change I'd just do on my own! =:0
At least, that's my story and I'm stickin' to it.
On Mon, Jun 13, 2011 at 2:46 PM, Ken <klehman@albedo.net> wrote:
As far as I'm concerned there is no problem using those extra long
stainless rivets if there is room as they seem to pull the same.
My older manual does mention stainless rivets there but does not specify
a size. I elected not to use any stainless rivets on my doors as they
are more difficult to remove. I figured sooner or later someone would
bend the door requiring some rework and I'd end up cursing stainless
ones. I did use a few more aluminum ones on the hinge than specified and
I may have used a few structural Q aluminum rivets at the top and bottom
where I thought it might help.
by Ken
On 6/12/2011 9:57 AM, Terry Dazey wrote:
Hello Rebel Builders:
Rebel Manual 23.0 Door Assembly (29/06/98) Pg.7, Number 17
The manual says to attach the door to the forward vertical stainless
hinge using 1/8 x 1/8 Stainless rivets (assumed RV5402).
Unfortunately, I do not have the RV5402's on my MAM packing list and
none in stock. The closest stainless rivet I have in my stock is
RV5404 (1/8 x 1/4) which look a bit long for the thickness of
material. Is this an acceptable rivet or should I order some RV5402's
for the application?
Thank you in advance for information.
Terry Dazey Rebel 662 Lake Tapps, Washington USA
by Terry Dazey
Thank you Mike, Ken and Ron for your answers to my door hinge rivet question.
Seems the consensus is to use aluminum rivets and keep an eye on them. Yes, Ken,
those stainless rivets are a bugger to remove. Unfortunately, I did not plan, nor
did I drill any additional rivet holes at the hinge. However, the plan is to use
the standard RV1610 aluminum rivets, and if I can locate a couple of Q aluminum
rivets locally, I will use those top and bottom as Ken did.
Thanks again for the suggestions.
Over-and-out . . .
Terry Dazey
R662
PS: Prior to my initial post to the group, I did accomplish a search on Rebel
archives for "Rebel Door Hinge Rivets", "Door Hinge", "Door Attach" and "Door Rivets"
with no success. Hmmm . . . maybe it is just me?
--- rshannon@cruzcom.com wrote:
Subject: Re: [rebel-builders] Rebel Door Hinge Rivets
Date: Mon, 13 Jun 2011 17:08:37 -0700
by Joel Jacobs
I have a staggered double row of rivets up my door posts. The door
hinge material I have will have insufficient edge distance to pick up
the forward rivets. Is it ok to trim the hinge a bit and just pick up
the rear row or should I get some wider hinge?
Joel
Rebel #416
by Ron Shannon
Trim the hinge to clear, or sit flat behind the forward row. One row
of rivets in the hinge is fine.
As you probably know by now, aligning the doors can be tricky, and
takes awhile. You may have to trim that hinge edge more than once, so
take it slow.
On Sun, Jun 19, 2011 at 3:55 PM, Joel Jacobs <jj7499@gmail.com> wrote:
[quote]I have a staggered double row of rivets up my door posts.
by drewjan
The double row of rivets isn't there to support the door but to help spread out shearing forces from hard landings. I'd just rivet it as is. The close edge distance isn't going to hurt anything.
Sender: mike.davis@dcsol.com
Date: Sun, 19 Jun 2011 18:55:01
Joel
Rebel #416
