[rebel-builders] Tailwheel leaf springs/shimmey!
Posted: Sun Feb 19, 2012 11:51 pm
Wow! Tough one. Jesse, is that your normal spring shape? It looks like a
greater angle than my aronca spring and I thought that's what you had as
well. I know there are many flying for a long time but I still say the TW
hardware on our rebels seems pretty light! Good Luck. Craig
To: "Builders list" <rebel-builders@dcsol.com>
Sent: Monday, June 06, 2011 2:27 PM
Subject: [rebel-builders] Tailwheel leaf springs/shimmey!
Have been struggling with a bad shimmy that I thought I had mostly figured
out...until yesterday. I installed a 2 leaf steel spring in place of the
fiberglass one and had been having good luck for the past 40 hours despite
needing to have it re bent to get a more horizontal castor angle.
Yesterday it shimmied bad enough to bend the clamp assembly (see pics) Now
I'm back to the drawing board and considering all options. I will need to
fix or remake/reinforce the tail strut support angle as well as modify the
leaf springs or replace them with something else. Any ideas? I had a
beautiful weekend of flying before the destructive shimmy, so I have that
to motivate me to get it fixed. Also, I now know that I can successfully
hold the tail up with brakes until slowing to a slow taxi speed. I got it
to the home airport after the bad shimmy happened at a fuel stop.
thanks.
Tailwheel leaf springsshimmey!
http://cid-f0168b2944a206d0.skydrive.li ... GXyc8PA%24
